[C1] Hurst competition plus muncice replacement
Old Nov 30, 2022 | 09:37 AM
craigakiyama's Avatar
craigakiyama
Default Hurst competition plus muncice replacement
65 muncie in a 59, want to use t handle shifter, their are so many different applications, try to find correct replacement shifter mech. my shifter is welded.3216274
Old Nov 30, 2022 | 01:19 PM
Tooth Doctor's Avatar
Tooth Doctor
If that shifter works, why not just get the T-handle shift **** that Hurst makes?
Old Nov 30, 2022 | 02:16 PM
Hermn59's Avatar
Hermn59
I had the same thing with mine. I sent my shifter to Hurst Online and they rebuilt it and replaced the welded handle plate with the plate to allow the bolt-on T-handle. I have the welded handle for garage art.
Old Nov 30, 2022 | 02:34 PM
JF in MI's Avatar
JF in MI
Pro Mechanic
2023 C1 of the Year Finalist - Modified
I had the same thing. My '60 came with a Muncie and Comp + and, having owned one before, love the way the Hurst shifts but wanted a stock looking shifter. I cut off the Hurst handle, ground away half the stub thickness, drilled and tapped it for the bolt on 'stock look' shifter. Cake and eat it.
Old Nov 30, 2022 | 02:58 PM
Hermn59's Avatar
Hermn59
Much more industrious than I. Nice work!
Old Nov 30, 2022 | 10:26 PM
craigakiyama
Thanks for that I'm assuming the bolt holes are 90 deg. to the transmission, did you have to remove it from the housing, almost looks like you have to.
Old Dec 1, 2022 | 07:25 AM
6T7L71CPE's Avatar
6T7L71CPE
Many like that original handle shape and they don't make an exact copy for the bolt in shifters. You could sell yours and buy a new one or maybe someone will trade with you.
Old Dec 1, 2022 | 07:45 AM
JF in MI's Avatar
JF in MI
Pro Mechanic
It was about 6 years ago so TBH I don't remember but you're probably right on having to remove it. Was real easy to do, just get the replacement lever first so you can see how much/where to cut it and where to line up/drill the holes.
Old Dec 1, 2022 | 08:47 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I have a Hurst for a 63-65 on the Muncie in the 56, and a bolt-on replica 56-58 handle. The result is the positive shift of a Hurst and a factory appearance.
Old Dec 1, 2022 | 10:53 AM
craigakiyama
I'm going to try that, looks like the part is 150.00 if I screw up, probably end with a stronger part in the end Thank You
To Hurst competition plus muncice replacement
