[C2] Tach etc...
Old Dec 22, 2022 | 03:44 PM
Vetter62's Avatar
Vetter62
Default Tach etc...
Hey all - does anyone know if the tachometer and odometer in a '66 are tied together in any way? My tach quite working a while back but I noticed later on that the odometer wasn't working either. When I fix the tach, will the odometer work again as well?
Old Dec 22, 2022 | 03:52 PM
boxster99t's Avatar
boxster99t
Each can work or break independently of the other in my experience. On my 67 the speedometer gears in the cluster stripped (also taking out the odometer/trip odometer) but the tach continued to work.
Old Dec 22, 2022 | 05:04 PM
TAlvarez's Avatar
TAlvarez
The tach is driven by a cable from the distributor. The speedometer/odometer are driven by a cable from the transmission. They have nothing to do with each other.
Ted
Old Dec 22, 2022 | 05:21 PM
Tuco888's Avatar
Tuco888
If they’re both original then it should be no surprise that they both break around the same time frame.
Old Dec 22, 2022 | 05:27 PM
Vetter62's Avatar
Vetter62
Thanks for the replies 'vette people - that's what I needed to know.
Old Dec 22, 2022 | 07:42 PM
Avispa's Avatar
Avispa
They're not tied together in any way. Completely independent operation.
Old Dec 23, 2022 | 06:41 AM
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
Tach should be an easy fix (start with the cable).
The speedometer / trip meter is not as easy. There is a little gear made out of cheese that fails in the speedo. This will require the dash to come out and the speedo can go out for rebuild.
Good luck!
Old Dec 23, 2022 | 08:45 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
If it makes you feel better, it's not unusual on cars of this age. You'll find lots of info in previous threads.
To Tach etc...
