[C1] 1954 Corvette engine stamp
Old Jan 1, 2023 | 08:51 PM
rambok81's Avatar
rambok81
Default 1954 Corvette engine stamp
Any help decoding this number? The seller states it’s the original engine but the car is an automatic and I’m finding the 54z is for a manual. Any help would be appreciated.
Old Jan 1, 2023 | 08:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
all 54 were autos
Old Jan 1, 2023 | 08:58 PM
rambok81's Avatar
rambok81
Default Re
Yes I’m reading the corvettes should have a YG and not a Z. Just trying to confirm
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Definitely NOT the original engine for that or any 54.
Old Jan 1, 2023 | 09:08 PM
jim lockwood
Definitely "YG":
Old Jan 1, 2023 | 09:37 PM
rambok81's Avatar
rambok81
I appreciate the quick responses and help. Just wanted to confirm what I’ve been reading on a couple sites. Now have to break the news to the seller who thinks it’s the original engine.
Old Jan 2, 2023 | 07:56 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
YG only for 54
Old Jan 3, 2023 | 02:42 PM
emccomas's Avatar
emccomas
Here you go...
1954 Engine Specifications
Model & Code No. Cylinders CID HP Comp. Ratio Carb. Trans.
One-Fifty, Two Ten & Bel Air passenger cars
Z 6 235 115 7.5:1 1 BC STD
Y 6 235 125 7.5:1 1 BC Powerglide
Corvette
YG 6 235 150 8.0:1 3 x 1 BC Powerglide
Old Jan 4, 2023 | 09:22 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
The stamp on the motor is good but just not Corvette
ALL 54 Corvettes are suffix F54YG - ALL
F is for Flint and YG is a for Corvette
The stamp is original - the first 5 characters are gang stamped and the next two are individually stamped
The F54Z in this case is also gang stamped and is tilted to the right
Also check the head - the head should be a 241 - if it is not - it is not a Corvette head - the number is on the drivers side by the valve cover
The block should be a 911 block - casting number is down by the fuel pump
Old Jan 4, 2023 | 09:23 AM
csherman's Avatar
csherman
Also - ALL 53 and 54 cars were powerglides - ALL
Old Nov 28, 2023 | 02:59 PM
Behiel's Avatar
Behiel
Cruising
Default '54 Engine Stamp ends in Y. Why?
My '54 engine stamp is 0121 604T54Y. It ends in Y and not YG. Anyone have an explanation? Thanks in advance.
Old Nov 28, 2023 | 03:45 PM
Chuck Gongloff
Model & Code No. Cylinders CID HP Comp.Ratio Carb. Trans.
One-Fifty
Two-Ten
Bel Air
Corvette
YG 6 235 150 8.0:1 3 - 1 BC Powerglide
Passenger car stamping Y as indicated above. Also a Tonawanda, NY assembly with the letter "T".
Old Nov 28, 2023 | 03:50 PM
Behiel's Avatar
Behiel
Cruising
Thanks Chuck,
In your opinion, is this consistent with a 54 corvette?
Old Nov 28, 2023 | 04:15 PM
Chuck Gongloff
Originally Posted by Behiel
Thanks Chuck,
No, it is not.
Old Nov 29, 2023 | 09:27 AM
csherman's Avatar
csherman
No
YG is the suffix for Corvette
Chris
To 1954 Corvette engine stamp
