Newby here, I am trying to figure out my engine stamp info....not finding what I am looking for so I come here for help.
Have a 1961 Corvette
Block Casting # 3756519 seems correct
Stamp # HDK F0425M Flint, April 25th Mexico ?
What is the HDK ? found HD info, but the "K" I cannot find.
The "M" after the assembly date, identifies the engine, not the "HDK" before it.
"F0425M" decodes as a Flint built (F) engine assembled on April (04) 25th (25), and the "M" identifies it as is a 2bbl, manual trans, 283 out of a Chevrolet truck. The "M" suffix code was used for 56-57 265/155 truck engines, 58-62 283/160 truck engines and 63-64 283/175 truck engines. The 3756519 block was used for cars and trucks from 1958 to 1962, so your "M" code engine is out of a 58-62 Chevy truck. To determine exactly what year truck it came out of, the casting date on the engine rear flange, on the opposite side of the block from the casting number, needs to be known.
What the "HDK" is I don't know, but it could be an engine rebuilder's mark, or some mark put there by someone else for some reason. In 61 only Corvette engines, and some high horse passenger car engines (mainly 348's and the handful of 409's built) got a VIN stamp. Truck engines didn't get VIN stamps till it became Federal law in 68, so the only thing usually stamped on an earlier truck pad would be the code for the assembly plant, the month, day and the letter identifier for the engine suffix code.
A picture of the pad, might shed more light on what the "HDK" is.
The suffix code is “M” the decides to a truck engine there never was a vin stamp on an engine with less than 300 advertised horse power until 68. HDK was stamped after the engine left any GM assemble plant so it’s meaningless unless the guy you bought it from initials are HDK
Vin derivative stamps on engine pads for Corvettes started in late Dec of 59 for the 60 model year at the same time the vin plate moved from the door sill to the steering column. That was for all horsepower from 230hp 283's all the way up to and including fuel injection. Engine pads were stamped with vin derivatives on all Corvette engines after that. The below picture is an example for a 61 283 230hp.
I should have been clearer by saying in that stament is true for all other chevy cars and trucks but not Corvette. and since this block came from a truck that's how applies
As I said in my previous post, the suffix code is the "M" after the "F0425", and is what identifies it as a truck engine. IF it was the original engine, it would have a portion of your VIN stamped in the area where the "HDK" is stamped. That "HDK" was NOT stamped on the pad by GM, and as I said in my previous post, is more likely something stamped by someone like an engine rebuilder as a warranty identifier, or by someone for some other unknown reason.
or number opposite block stamp
Again, appreciate your help
On the right (passenger side) REAR of the block, on the flange that the trans bolts too, and opposite of where the block casting number is, is where you will find a block casting date. This date will be made up of a letter for the month (likely a "D" for April, one or two numbers for the day of the month, and a single number for the year (such as a "1" for 1961). With the date it can be determined what year engine it is.
I asked, just ask the wrong people.
It makes me feel like a idiot, smarter now, but education is expensive.
Don't feel bad, many if not most of us have been down the same road, often more than once. In my case I did it 40 years ago, and have slowly learned from it since.
Do you like the car, does it run and look good, then don't worry about it. Drive it and enjoy it. Face it, very few 60 year old Corvettes still have their original engines, even many of those with the "correct" and "matching" numbers stamped on the pad.
follow up question .... I get that engine "was" from truck @ 160HP
When rebuild was done they used correct parts
it was added to this block 3756519
and correct cylinder head 3739653
and correct dual quads 2626S & 2627S
Would this not get HP close to the 270hp as if it had come from factory ? or somewhere close to that?
The big decider to your question is what cam did they install...along with the correct heads and carbs. But, yes, it certainly could be made into whatever you wanted. An engine block doesn't know what it's supposed to be until you build it. If the horsepower output is what you're concerned about, you might consider having your car dynoed.
hp is just important as to I want to see if I got what I paid for....
Dyno test might be interesting to have done.
thanks again... think I have all I need, for now.
I am going to say you will be disappointed either way. you can ask the seller for any paperwork or receipts from the engine build to see what parts where really used. if you have access to a inspection camara you can stick it down the spark plug hole and see what type of pistons were used.
Those are not the correct dual quads for a 270 horse engine. The 2626S & 2627S are for the 245 hp with hydraulic lifters. The 270 hp has 2612S & 2613S WCFBs.
Bob
59 245hp
waving in San Diego
