Point wear ?
Old Jan 6, 2023 | 11:10 AM
Projet1960's Avatar
Projet1960
Default Point wear ?
Hi, I dismantled my distributor for a serious cleaning and to fine tune the ignition settings afterwards. Can you confirm whether or not the little hole in the centre of my point is normal or the result of wear?
(Standard SBC 283 ci distributor, single point). Thanks
Old Jan 6, 2023 | 11:20 AM
TAlvarez's Avatar
TAlvarez
That point set was manufactured like that. I believe that the idea was that design would have less pitting/burning of the contacts.
Ted
Old Jan 6, 2023 | 11:35 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Yep, that hole is there on purpose.
Old Jan 6, 2023 | 11:36 AM
Ron Miller's Avatar
Ron Miller
Ted
Center hole allowed for a bit more ventilation and cooling . . . . .
Old Jan 6, 2023 | 12:19 PM
Plasticman's Avatar
Plasticman
That is not a Delco set of points, but is designed more of gimmick, that does little.. Fine for low rpm non-performance engines.
If you have a higher revving engine, recommend replacing them with a quality set from NAPA (Echlin) or Accel.
Plasticman
Old Jan 6, 2023 | 03:33 PM
Projet1960's Avatar
Projet1960
Thanks for your quick answsers !
Old Jan 6, 2023 | 04:17 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
If pitting occurs on the stationary side of the point assembly that is an indication of an under-capacity condenser. Conversely, pitting on the arm is a result of an over-capacity condenser.
To Point wear ?
