[C2] 67 L-79 Distributor Question
I was setting the ignition timing on my 67 L-79 and took off the distributor cap and noticed two very small square magnets on the side of the distributor ( see photo). Any idea what these magnets are? Appreciate any insight.
Received 2,132 Likes
Is this the first time you have seen these? Never seen anything like that before. Are they attached to the breaker plate or the base? They are not stock. Dennis
Maybe if the wire is broken that grounds the breaker plate to the vacuum advance screw (distributor body) is missing/broke then they provide a ground path for the primary ignition circuit.
2021 C5 of the Year Finalist - Unmodified
Could those be magnets from a previous pertronix unit?
The following 2 users liked this post by Six7390gt:
FrankieW (02-14-2023),
leif.anderson93 (02-14-2023)
Six7390gt (02-15-2023)
