[C2] gauge cluster guide
Old Feb 17, 2023 | 01:24 PM
rowingone's Avatar
rowingone
Default gauge cluster guide
For those of you that intend to remove your dash cluster for restoration I found this handy guide. It includes wiring and blub placement. Anyone have a quick way to replace those turn signal indicator lens without removing the cluster?
Old Feb 17, 2023 | 03:41 PM
Avispa's Avatar
Avispa
To replace the turn signal indicator lenses, the gauge mounting plate with gauges attached has to be removed from the cluster housing. The speedo and tach sit at least 1 or 2 nches deep in the housing. Even if you could reach all the mounting plate screws with the cluster installed (you cant), there isn't enough room in the dash behind the cluster to pull the gouges out. Don't waste your time. Pull the cluster out.
