C2 paedal assembly install
Old Mar 11, 2023 | 03:05 AM
Steve 66's Avatar
Steve 66
Default C2 paedal assembly install
My reproduction Z bar has no captive nuts , am I right in thinking the pedal assembly bolts to that then the column hangs of it ? If so is there a dimension from hinge pilar to these nuts ?
thanks
Old Mar 11, 2023 | 05:48 AM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Is your z bar installed yet? If so are your 2 round support rods in? If yes bolt your pedal assembly to the firewall and it will locate the holes for you. Yes the column hangs from it.I can get the measurements later today.
Old Mar 11, 2023 | 06:00 AM
Steve 66's Avatar
Steve 66
still got fabricate the 2 support rods
Old Mar 11, 2023 | 07:18 AM
Steve 66's Avatar
Steve 66
Tacked Z bar in and hoping to use it to set hinge support angle . As you can see I can’t get top hinge in now hinge support is in car
Old Mar 11, 2023 | 06:27 PM
Greg Hollowaty's Avatar
Greg Hollowaty
67 AC Coupe - I will look at and locate the nuts on Monday.....
Old Mar 12, 2023 | 06:50 PM
Greg Hollowaty
Brake Pedal Housing Attachment to Z Bar
Left Nut @ 9-7/8"
Right Nut @ 12-15/16"
Note that this mounting surface is not formed at that same angle as the surrounding metal.
This is the location for the Hood Release Bracket mounting.
Old Mar 13, 2023 | 01:10 AM
Steve 66's Avatar
Steve 66
That’s great thank you
Old Mar 19, 2023 | 07:20 AM
Steve 66's Avatar
Steve 66
Thanks to this group I have sourced and fitted my pedal assembly
To C2 paedal assembly install
