Engine tight
Old Mar 14, 2023 | 10:55 AM
Little67red's Avatar
Little67red
Default Engine tight
Put my 406 together. Put rods and pistons in turned over at 33lbs.now I put oil pump on cam in front timing chain and damper on.now it takes almost three times as much to turn. Is this normal or is there something wrong.
Old Mar 14, 2023 | 11:09 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
My instinct is that something is wrong. I have two data points. Make of them what you will:
1. The tightest engine I've ever assembled required about 40 ft-lbs torque at the crank to turn it over. This is with pistons, crank, and stock valve train installed.
2. The TRACO 377 in my bride's Grand Sport required only 22 ft-lbs. This engine was a full roller motor, no sliding valve train surfaces
Old Mar 14, 2023 | 03:33 PM
Bgblock427's Avatar
Bgblock427
Just crank rods and pistons are 33lbs? way too tight, what are the bearing clearances at?
need more specifics on engine clearances, I have done vids on the difference just .001 will make on a crank main.
piston to wall clearance? type of piston used?
were the rods installed correctly they have a camphor on one side that goes towards crank fillet
lot goes into assembly.
Old Mar 14, 2023 | 05:01 PM
pop23235's Avatar
pop23235
What kind of ring gap?
Old Mar 14, 2023 | 05:11 PM
Vette5311's Avatar
Vette5311
To tight, if you think bearing clearance is good, check rod sideplay and crankshaft endplay.
Old Mar 14, 2023 | 05:58 PM
TheDucci's Avatar
TheDucci
This where I would start looking? You did not say if the pan is on or not, if not check the bottom end for correct orientation.
I always use a black sharpy with notes all over my motors with plenty of pictures so I can go back and double check stuff.
Old Mar 14, 2023 | 06:25 PM
Vette5311's Avatar
Vette5311
Also, did you check piston skirt clearance (correct bore/hone) before putting pistons in? Just a thought.
Old Mar 14, 2023 | 07:20 PM
andy60's Avatar
andy60
Default Tight
I have used thick assembly lube in a cold garage that made it harder to turn. Not sure that much, I would double check everything that could bind and start with your main bearings. Did the timing chain go on ok?
Old Mar 14, 2023 | 07:26 PM
jim lockwood
Been thinking about this some more.....
I assume you mean 33 ft-lbs? (Let's use correct terminology.) That by itself is really high.
Is there any chance you got some of the main bearing caps out of place? Or even some rod bearing caps?
Old Mar 14, 2023 | 07:38 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
What were the measured main bearing clearances, crank end play readings, and measured piston ring end gaps during assembly?
Did the bare cam spin smoothly when initially installed? How tight was the cam chain?
What is the cam lift and spring pressure at full lift?
Old Mar 15, 2023 | 09:05 AM
DansYellow66's Avatar
DansYellow66
I’m no engine builder and defer to the others on the 33 ft-lbs but setting that aside for the moment it sounds like something went horribly wrong when you installed the balancer and the fuel pump if you engine turn over torque shot up to the vicinity of 100 ft-lbs, I would remove those items one at a time and see if the turnover torque decreases to figure out which one is the culprit. You definitely need to figure that out. Then check the overall assembly for clearances.
Old Mar 15, 2023 | 11:02 AM
joewill's Avatar
joewill
plastigauge is your friend for your bearing clearances...
if your heads are torqued down then you will be fighting compression too .. if your spark plugs are in..
To Engine tight
