Trans code
Old Mar 18, 2023 | 09:41 PM
MC vet's Avatar
MC vet
Default Trans code
I have a 67 with trans date code P7M24 it has the correct vin stamp on the opposite side and cannot find what the M24 code is, thanks
Old Mar 18, 2023 | 09:49 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
What trans, automatic or If its a 4-spd, M=August, 24. Dennis
Old Mar 18, 2023 | 10:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Autos won’t have a vin stamp
Old Mar 18, 2023 | 10:20 PM
R66's Avatar
R66
The date code on the automatics is on the pan of most GM transmissions from the late 60s . You can swap the pan to another transmission (PowerGlide or TurboHydro) of the correct casting and have a correct transmission.
I believe the date code on the Muncie is what the OP is asking to clarify, not the VIN.
Old Mar 18, 2023 | 10:29 PM
MC vet's Avatar
MC vet
Sorry, it's a 4 speed, ya I didn't think autos had a stamp, hey thanks guys you are a wealth of info, I am new to the forum and have already learned a lot even though I have owned and maintained 13 of these since I was 20......that was 50 years ago! Never too old to learn!
Old Mar 19, 2023 | 01:38 AM
Vet65te's Avatar
Vet65te
MC - Saw you've had a few posts already and scanned through them and if no one else said it already...Welcome to the Corvette Forum.
Also saw you mention you had what you believed was a potential overheating issue with your 67 L71. Did you get that rectified?
Mike T - Prescott AZ
Old Mar 19, 2023 | 10:54 AM
MC vet's Avatar
MC vet
Your the first welcome Mike, thank you I am looking forward to reading the forums and posting my issues.
As far as my heating problem with the 67 L71, John Z gave me advise about the vacuum advance and I ordered a upper radiator seal kit for an A\C car from Paragon,I got that idea from the one on my L 79 car withA\C,but Its been cold and nasty weather here in Missouri so haven't had a chance to put the two to the test, I just got back from a couple months in Arizona. Maybe I'll look you up when I return next year.Thanks Vet 65
Old Mar 19, 2023 | 04:06 PM
Vet65te's Avatar
Vet65te
MC - Those two suggestions were going to be the first two I was going to recommend, repiping so you get full manifold vacuum to the distributor vacuum pod and using that upper A/C rubber flap to help direct additional air through the radiator instead of some of it going up and over. I'm guessing your visits to Arizona are to the Phoenix/Scottsdale Valley and we're about 90+ miles due north of that area but if you do find yourself up our way, do contact me and stop by for a visit. And if that return trip to AZ has you here around late September, the Prescott Vette Club has their annual Vette Show
at that time with about 300 Corvettes with about 30-40 midyears and solid axles Vettes in attendence.
Old Mar 19, 2023 | 05:10 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
P = Muncie
7 = 1967
M = August
24 = day of the month
Old Mar 19, 2023 | 08:28 PM
MC vet's Avatar
MC vet
Ya Mike that made good sense to me also, I'm anxious to see the results. I winter in Casa Grande and know where you are located.....not too far away.
DZAUTO thanks for your info, I just purchased this car....67 coupe,L79 with a\c and power steering,(I did the # checking) I have had many of the C2s and C3s over the years but never much checked #s ...just drove em! My last car before this one and the L71 was a 66 427 390 roadster non matching engine, it was an IL block out of a 68 which I built back in 89 but I had it for 32 years so the # game is somewhat new to me, which brings me to the carb date on the L79 of 1711, it has the correct 3810 list but don't know the date.
Thank you guys....MC
Old Mar 19, 2023 | 08:31 PM
Nowhere Man
That carb is something 1971,1981 or 1991
Old Mar 19, 2023 | 08:52 PM
Nowhere Man
Also that can’t be the correct trans if that is truly augest of 67 as the last 67 was built in July
Old Mar 19, 2023 | 09:47 PM
DZAUTO's Avatar
DZAUTO
The digit for the year (in this case, 7) is NOT, repeat, NOT the year it was assembled. It is the year model of the car it was for. Thus, MOST PROBABLY, it was built Aug 24 in 1966 for a 67 car. Yes, that seems kind of strange, but that is how the date codes for Muncies was done.
Old Mar 19, 2023 | 10:53 PM
leif.anderson93's Avatar
leif.anderson93
Just out of curiosity, what is the last five of the VIN stamp?
Old Mar 20, 2023 | 08:02 AM
Nowhere Man
Tom thanks for that. That is an odd way of doing a date stamp of all the other dating practice done by GM suppliers this is a new one on me.
Old Mar 20, 2023 | 08:50 AM
MC vet's Avatar
MC vet
That was very helpful info on the trans date, thanks DZ
The last 5 of the vin 07032
Old Mar 20, 2023 | 09:37 AM
Bluestripe67
My '67 was built Oct 24, 1966 vin 2483 well documented, so his car vin 07032 was built in Dec. 1966. That would make the Aug build of the trans reasonable. Dennis
To Trans code
Old Mar 20, 2023 | 10:08 AM
leif.anderson93
Approximate birthdate of Dec 30, 1966. August trans with a correct VIN stamp is logical.
Old Mar 21, 2023 | 02:11 PM
MC vet's Avatar
MC vet
I have an NCRS shipping document that came with the car stating the production date was Dec. 29 1966 so ya Bluestripe according to your info mine should have the correct trans. Thanks to all again......now back to work on the L71 heating problem!
Old Mar 21, 2023 | 03:54 PM
Nowhere Man
for your overheating problem
http://www.camaros.org/pdf/corv_cooling2.pdf
