Increasing caster
With the oem arms , i read to put shims to get the desired camber , and less shims at the front bold to get positive caster.
How much difference can we do that way with shims ? Will less shims on front bolt also alter camber ? and to what degree ?
Is there a "optimum" setting in shims thickness differences for a bit negative camber and max caster ? Or does all depend the specific car ?
Popular Reply
Here is what the GM Service Manual Section 3-5 says about shimming:
"Caster - change shims at either the front or rear of the shaft. The addition of shims at the front bolt or removal of shims at the rear bolt will decrease positive caster. One shim (1/3 2") will change caster (approx.) 1/4°. Camber - change shims at both the front and rear of the shaft. Adding an equal number of shims at both front and rear of the support shaft will decrease positive camber. One shim (1/32") at each location will move camber (approx.) 1/5° (Chevelle and Camaro); 1/6° (Corvette)".
I started with the maximum shims on the rear bolt to obtain maximum Caster. I ended up with about 1.5 degrees on each side. Then I added shims to the front bolt as needed to get 0 degrees Camber. The caster is reduced when you add shims to the front bolt and not the rear also.
These cars were built to utilize positive Camber due to bias ply tires. Radials require 0 degree or negative Camber. To obtain more Caster and 0 degrees negative Camber, Moog sells offset upper control arm shafts. For the performance (track) alignment, most recommend more negative Camber. Thus adding more shims to both the front and rear bolts equally.
I believe each car is different due to age and sagging of the frame. I don't know that a specific thickness shim pack will work on every C-2. This problem is even more pronounced on the cars with front subframes, as the total shim pack thickness on one side may be greater that the other side. I discovered this on my 68RS Camaro.
I apologize for getting carried away and providing more than you asked for. Hope this helps.
Ron
Ron
I can follow your suggestion , as i never read here :
start with max shims at rear bolt ( i assume full threaded nut ) , then add shims at front bolt to get the desired camber. The caster result is then at max positive possible .
Okay , will try that and see what it gives.
Hoping I did not mislead you, but it worked for me.
Ron
I have now 5x 1/8" shims at the rear bolt , which is max for clearance. I see enough thread for another two , but can't do it.
But must wait for P/S parts to finish that job , so i can test drive it. I trust camber/caster measurements only after driving it a bit so all can settle and i sure don't need to lift the front for the rotating tables. Just drive on them and measure.
