[C2] Splash Shields
Popular Reply
Elwood
Yes they are completely flat. You may find 1/8" thk 7075 difficult to fabricate & an expensive material selection for this application; especially if your stock is T6 (xxx) temper. Pic's attached are similar project using 14 gage (~.063") 6061 T6. Very easy to handle, punch, cut & the like. I elected to have a couple rows of olde'-school louvers on mine to (perhaps) let heat & other evil-spirits escape.
Elwood
Vark, that is exactly what I wanted to do as I had seen yours and Black Magic’s. After looking at it, I kinda figured my aluminum might be too thick. I have a 4’x6’ piece that was given to me years ago. Thought I might put it to use. I did cut a piece to to mount my amp and crossovers on for the rear bulkhead. That will be covered in carpet. Sending you a pm with some questions.
What is the purpose of the U-shaped cutout on the driver side shield? I have a 67 convertible and I’m not sure what would run through that cutout.
I found a local guy to do the louvers and purchase some 5052 aluminum scrap for $20. I have the pieces cut out but wondering if I need that cutout?
So I guess they just used the same plates in 67 or mine is not original. My car was built in December 66. I have enough scrap to make one without the cutout as I like the look of the solid piece better.
A thanks to Vark for answering some more questions I had on these.
I had enough aluminum left over to make one without the cutout and went by the fabrication shop I found about 40 minutes away. I thought I was just going to drop them off but he went to work on them right away. I plan on powder coating them when I take some other things though they might look cool with a brushed aluminum look. Went ahead and had him do the one with the cutout. Guess I have a spare on that side. Lol.
I asked him how long he had been fabricating and he said he started in 1963 in the family business. He makes parts for and builds/restores old dragsters like the one in the pic below. I don’t know the official name of these so I added a pic. Turns out on this car he made the driveline disconnect. He also had a hood he was putting a bunch of louvers in as well.
Dennis
