Oil Analysis
Old May 3, 2023 | 09:24 AM
C2Dude's Avatar
C2Dude
Default Oil Analysis
1st Blackstone Labs oil analysis on my 66 L79 that I have done since owning her. Mileage shows 39K but that is unconfirmed and unlikely accurate. Their review up top pretty much explains the results but I wanted the engine guy's opinions. Oil pressure shows good on the gauge. Early on when I bought her I did a compression test and the results were a bit low at the time. That said she burns no oil, exhaust once off the choke is clear and she runs fine. I did remap the distributor when I rebuilt it and max advance comes in around 3K, no audible pinging that I have noticed although my hearing is not what it once was.
What do you think? I plan to repeat the study in the Fall.
Old May 3, 2023 | 09:56 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I think it looks to be in decent shape. Just trace fuel in the oil, no coolant, and no water. That is good as far as rings and passages sealing well. Do you use additives or leaded gas? From a single test you really don't know what's going on with the lead and tin. Your thought to put a few thousand miles on it and retest is a good one.
Old May 3, 2023 | 10:39 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Paul, we used to send locomotive oil for analysis (a whole lot cheaper to only change it when there is a problem when you're talking 200 gallons capacity). You already know the following but if it helps anyone: The first test does 2 things - it tells you if something is wrong right now, and it establishes a base line for comparison on future tests. On the subsequent tests you can track the percentages of various elements and anticipate a problem way before it would otherwise be apparent. If something starts going up, it will point you in the direction of the issue.
Old May 3, 2023 | 11:26 AM
C2Dude's Avatar
C2Dude
Yes guy's were on the same page. On my aircraft it was best practices to run oil analysis annually so as to hopefully see a disturbing trend long before the big fan up front stopped spinning during an inconvenient moment.
I generally do a filter/oil change before and after the driving season, so I'll revise this thread in the Fall.
Old May 3, 2023 | 11:29 AM
Railroadman
Before AND after the driving season?
Old May 3, 2023 | 03:17 PM
C2Dude's Avatar
C2Dude
yeh, I generally aim for a 3K driving season so that works out about right. I recognize that there is no mileage on it in the Spring but I change it a few drives before she is tucked away for the Winter, so the oil is fresh and again after the first drive of Spring due to likely condensation that accumulated over the Winter. I could skip the Spring filter, but K&N is cheap enough that I swap it out as well.
Old May 3, 2023 | 10:43 PM
barkingrats
Given your oil analysis, I think a spring oil change due to storage and any condensation is unwarranted. There's no water in your sample and there's extremely little use of the oil, so seems an exercise in spending money and effort where it's not needed. The elevated tin and lead are not a result of winter storage. Just my 2¢.
Old May 4, 2023 | 07:03 AM
C2Dude's Avatar
C2Dude
OK Owen, probably could eliminate that change, save up for bearings. Assuming the metals are from bearings, do these things fail gradually or is that something that suddenly leaves you on the side of the road. We have two 7-10 day road trips planned this year and when the day does come to pull the motor I would prefer to do it as Winter approaches so I have months to do the work and get it back in bed.
Old May 4, 2023 | 07:33 AM
Vega$Vette's Avatar
Vega$Vette
IMHO You're over thinking this. Drive the car, change the oil once a year and enjoy.
Old May 4, 2023 | 09:50 AM
barkingrats
In my experience, unless a bearing spins out of place, the wear is pretty gradual and you'd hear a knocking from the excessive clearances. I'll leave it open to others with much more experience to chime in on this.
Old May 4, 2023 | 09:51 AM
BAmacker's Avatar
BAmacker
+1. I've done hundreds of oil analyses in my HD truck life and I wouldn't worry about what I see above. Drive it.
To Oil Analysis
