Distributor question
Old May 9, 2023 | 10:18 AM
deejaydu's Avatar
deejaydu
Default Distributor question
What is the value of a straight axle dual point tach drive distributor? It has its tag on it but I have it packed away and don't remember the number.
Jay
Old May 10, 2023 | 10:41 AM
deejaydu's Avatar
deejaydu
200,400,600. Does anybody really know.
Jay
Old May 10, 2023 | 10:54 AM
corvettekent's Avatar
corvettekent
2023 Corvette of the Year Finalist - Unmodified
2022 C1 of the Year Winner - Unmodified
I'll buy it for $50.
Old May 10, 2023 | 10:55 AM
silver837's Avatar
silver837
I would try to contact Don Backer . His main business is restoring distributers. My contact info for him does not have his new phone number. Hopefully a member here will see the post and update us.
Old May 10, 2023 | 11:04 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Going from (aging) memory here.....
Prior to '62, all dual point distributors were "891" models, notable for NOT having windows in the distributor caps for adjusting point dwell. You adjust points with two screwdrivers and a feeler gauge. A PITA, IMHO. Unless you need that distributor for the numbers, I'd put its value very low.
In 1962, a one-year-only dual point distributor, possibly an "895" model?, was used. This distributor takes a two window D-324 distributor cap which allows dwell to be set with a meter on a running engine. If you need a dual point distributor, this is the one to have. The D324 caps, however, may be hard to find. I don't believe they are being reproduced.
Old May 10, 2023 | 11:29 AM
deejaydu's Avatar
deejaydu
My memory says that 891 is correct. Thanks for the helpful information guys.
Jay
Old May 10, 2023 | 11:53 AM
jim lockwood
Wait...... I just re-read your original post and realized that you said this dual point distributor also has a tach drive. That makes it the one-year-only, 1962, "895" distributor.... a very good piece.
Don't throw it away!
Old May 10, 2023 | 02:03 PM
deejaydu's Avatar
deejaydu
Yes Jim it is definitely a dual point tach drive distributor. Now I will have to go and unpack it to confirm that the tag says 895. What is the value of an 895 distributor.
Jay
Old May 10, 2023 | 04:26 PM
silver837's Avatar
silver837
Don Baker
Old May 10, 2023 | 04:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Last I saw Glen @gbvette62 he has a NOS two window cap for sale
Old May 10, 2023 | 05:08 PM
Donald #31176's Avatar
Donald #31176
I believe the 62 327 340 dual point tach drive distributor is a 985. Lots of racers used it in the 60s.
Old May 10, 2023 | 05:29 PM
jim lockwood
Well, I got all the digits right. Just the wrong order.
Old May 10, 2023 | 05:43 PM
deejaydu's Avatar
deejaydu
Ok 985 it is. I will report back what mine is.
Thanks to all.
Jay
Old May 11, 2023 | 09:50 AM
Drummer Boy's Avatar
Drummer Boy
A-HA! This explains why my ditributor cap has only ONE window. One at the front, none at the back.
I obviously have the wrong cap.
I always wondered how one would set the rear set of points with the engine running.
As per your suggestion Jim, I only re-installed one set of points so ithelack of rear window is not critical.
I toyed with the idea of installing that second set of points "just because I could," but the car runs so well it seems pointless.
Anyway, thanks for the tip thought. I might search out a proper cap.
Thanks again.
Eddie
Old May 11, 2023 | 10:38 AM
jim lockwood
Thanks again.
Eddie
Hmmm.... I see what you did there......
Old Oct 28, 2023 | 07:36 PM
rad-man's Avatar
rad-man
Are you saying that the 985 can be installed with just the front point and it will function properly as a single point non-vacuum dizzy?
Old Oct 28, 2023 | 08:01 PM
jim lockwood
Originally Posted by rad-man
Are you saying that the 985 can be installed with just the front point and it will function properly as a single point non-vacuum distributor?
Any dual point distributor can be operated as a single point distributor.
Gm distributors close one set of points and, after a few degrees of rotation, close the second set. Then the first set opens and a few degrees later the second set opens.
To operate a distributor on a single point set, disable the set which closes first and opens first. Then set the dwell to normal specs for a single point distributor.
I have no idea how to modify a "dizzy".
To Distributor question
Old Oct 28, 2023 | 08:25 PM
rad-man's Avatar
rad-man
Thanks, I was reading about some dual points and they have half the number of lobes. However, maybe this isnt the case for GM. I recently discovered that I have a 985 distributor, and I've been having a hard time getting it set right - partly because I didn't realize my spare '65 points don't work with the 985.
I just took out the rear set of points and connected everything to the front that is accessible from the window. I still can't get the dwell below 37, so I either need to get some '62 points to work with the 985 or just go back to a Vacuum distributor.
Also, another member referenced a distributor as a "dizzy", so I thought you guys adopted some new vernacular while I was away for a few years
Old Oct 28, 2023 | 09:13 PM
jim lockwood
From '57 thru '74 all Chebby distributors with window caps use the same points. There is no such thing as "'62" points.
In later years there was a combination condenser/points, "Uniset", that was supposed to be compatible with window cap distributors. I have no experience with these but I hear rumors the Uniset are to be avoided.
Old Oct 28, 2023 | 09:36 PM
rad-man's Avatar
rad-man
well… that’s even more interesting. There’s a notable size difference in the spare set I have, and I couldn’t get the engine to start with the new one on.
I’ll give it another shot.
