Tachometer cable question
Old May 18, 2023 | 03:36 PM
PattiR's Avatar
PattiR
Default Tachometer cable question
I'm putting a tach cable on the '57, and can't recall how the core cable goes into the housing. Is the thrust button end toward the tach drive unit or on the end next to the tach?
Thanks,
Dennis
Old May 19, 2023 | 01:33 PM
Donald #31176's Avatar
Donald #31176
On a 62 the non bulb side should be inserted into the cable housing towards the engine compartment. The bulb end is on the dash side which screws into the tach. Believe the 57 is the same.
Old May 19, 2023 | 09:27 PM
PattiR's Avatar
PattiR
Thanks for the info.
To Tachometer cable question
