[C2] Ignition switch wiring question
Old May 20, 2023 | 12:09 AM
slwhittenburg's Avatar
slwhittenburg
Default Ignition switch wiring question
Redoing ignition switch wiring on 64 roadster. It's a resto but switch and wiring looks original. Wires look correct except one wire is not what I expected. The IGN wire which should be pink/black is two 18 gauge wires. One is pink/black and other is black. Is this correct? If so, where should black wire go? Thanks as always.
Old May 20, 2023 | 04:29 AM
65GGvert's Avatar
65GGvert
Normally the two 18 gauge wires are pink (or black with pink stripe). One goes to the ballast resistor and one goes to the top fuse in the fuse panel. I haven't see a solid black wire on an ignition switch.
Old May 20, 2023 | 07:37 AM
Calistoga C2's Avatar
Calistoga C2
Sounds like they may have eliminated the ballast resistor and ran a new wire, ignition to the coil.
Old May 20, 2023 | 09:39 AM
EJC22's Avatar
EJC22
Source: Wiring and Bench Testing an Assembled Mid-Year (’63-’67) Corvette Instrument Cluster Dave Zuberer and Tim Welsh May 2016
To Ignition switch wiring question
