[C2] Trim tag decode help
Old May 27, 2023 | 11:47 PM
Chitownhooligan's Avatar
Chitownhooligan
Default Trim tag decode help
Trying to get help decoding this paint. It’s 940AA which is silver, but it’s a 1964 and only thing I find with the AA is 1965 body with AA. Any help?
Old May 28, 2023 | 12:43 AM
dynodonh's Avatar
dynodonh
940AA is Satin Silver, 1964, St Louis build.
Old May 28, 2023 | 07:26 AM
Chitownhooligan
ok thank you. Online all I found that 940 is satin silver but nowhere can I find what the AA is for
Old May 28, 2023 | 07:34 AM
Dave Strickland's Avatar
Dave Strickland
It is a nice original St. Louis Trim Tag as well.
Old May 28, 2023 | 07:40 AM
65hihp's Avatar
65hihp
In 64, all StL body colors had AA after the number.. All AOS bodies had A.. Chevrolet was figuring out how Trim Tags would work with two body suppliers.
In 65, all colors had the same number, 900 followed by different two letter code for StL bodies, ie, 900AA for Tuxedo Black.. AOS bodies had only the two letter code without the 900. ie. A-A for Tuxedo Black..
Here is 923AA Riverside Red. And, notice that this StL Convertible has S in the body number, since build date E24 is after the approximate start date of Jan 20, 1964 for AOS bodies. Your StL Convertible has no S in the body number since your build date E3 precedes the introduction of AOS bodies.
Old May 29, 2023 | 01:35 PM
turbodave231's Avatar
turbodave231
Pro Mechanic
Pro Mechanic
1964 Trim Tag/Vin Tag Survey guy here! I captured your trim info. Can you please send me the last 8 of your VIN? I will share the entire survey with you in return.
Old May 29, 2023 | 06:20 PM
Chitownhooligan
Originally Posted by turbodave231
1964 trim tag/vin tag survey guy here! I captured your trim info. Can you please send me the last 8 of your vin? I will share the entire survey with you in return.
40867s108256
To Trim tag decode help
