67 Steering column problems
Old May 30, 2023 | 12:19 PM
08redrocket's Avatar
08redrocket
Default 67 Steering column problems
Kinda ugly gap!
Well, I have tried to install a new blinker switch on my 67 with telescopic. I have done this 5 times and they still do not work. I'm past the push in the clutch and the horn honks and getting shocked. Nothing of the blinkers works at all. Part two is I tried again yesterday and the telescopic system is rough. The column pulls out I feel way to far. Also, why such a large space when the column is extended? See pictures. Shouldn't there be some kind of covering in the space? No left over parts...
Old May 30, 2023 | 12:28 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The upper barring retainer is broken
Old May 30, 2023 | 05:10 PM
08redrocket
@nowhereman is that supposed to be "upper bearing retainer"?
Old May 30, 2023 | 05:18 PM
Nowhere Man
yes you can see the bearing race in your picture. that is supposed to be attached to the retainer
Old May 31, 2023 | 06:12 AM
Vega$Vette's Avatar
Vega$Vette
When the telescopic column is adjusted, by turning the lock ring counterclockwise, to move aft and forward the entire upper column moves including the turn signal housing. So there is obviously an issue.
2nd. If your horn honks when you push the clutch probably the wiring from the turn signal switch is damaged from interference with the clutch linkage under the dash. When you push the clutch pedal the damaged wires ground causing the horn to honk. Other wires may also be damaged causing you other signal issues.
Old May 31, 2023 | 07:09 AM
phil2302's Avatar
phil2302
If it was my car I would take the column out of the car and rebuild the whole thing. Not a lot of parts to it and much easier on a bench. If you take it out take a close look at the steering shaft where the lower bearing surrounds it. The shaft is often worn in there and out of spec.
Old May 31, 2023 | 08:37 AM
Nowhere Man
problem is there is not a whole lot of parts available
Old May 31, 2023 | 09:49 AM
mittens's Avatar
mittens
Does anyone make a rebuild kit? I would yank mine out and rebuilt it all at once. need to find a kit not peace part the whole thing.
To 67 Steering column problems
