intake ?
Old May 31, 2023 | 02:20 AM
Maury Ross's Avatar
Maury Ross
Default intake ?
Dose the intake manifold bolts have washers for a 66 corvette? Do they have washers? Thank you
Old May 31, 2023 | 07:15 AM
Patrick03's Avatar
Patrick03
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
I stand corrected. See below for better info:
Old May 31, 2023 | 08:15 AM
R66's Avatar
R66
I have never found any lock washers or flat washers on a factory assembled small block engine from the 60s era. Not saying they are not needed to prevent gouging of the aluminum intakes, but I don't think GM installed them at the factory. Bean Counter Savings you know.
Old May 31, 2023 | 08:19 AM
Maury Ross's Avatar
Maury Ross
Thank you Patrick
Old May 31, 2023 | 08:55 AM
Patrick03's Avatar
Patrick03
Thanks for that correction R66. I've edited my post to not confuse anyone.
Old May 31, 2023 | 09:50 AM
R66's Avatar
R66
No problem, if you corrected all of my posts, you would be a very busy man. It happens.
Old May 31, 2023 | 10:19 AM
66jack's Avatar
66jack
Use thread sealant, especially the ones under the carburetor both sides...
Old May 31, 2023 | 11:47 AM
phil2302's Avatar
phil2302
I know the factory didnt use washers but personally I think it is a good idea to use them for the aluminum intakes.
Old May 31, 2023 | 12:18 PM
Muttley's Avatar
Muttley
^ Agree. The Corvette vendors make small thin stainless washers for this purpose, that are somewhat unobtrusive. You may still get dinged on judging for using them, if that's a concern.
Old Jun 1, 2023 | 10:00 PM
mblake101's Avatar
mblake101
I have those small, thin, stainless washers on my 340 horse 63 aluminum intake. They fit perfect and almost invisible. 👍
To intake ?
