Hmmmm. I'm confused. The 1963 shop manual says that the Ignition Resistor should be 1.4 -1.6 ohms. The one in my car measures ~2.4 ohms. Does the quoted parts and accessory entry supersede the repair manual?? Where can I get a "Black Dot" resistor that is NCRS approved?
The .30 ohm resistor was matched to the 091 coil. Later in the 63 model year there was a service bulletin to address customer complaints regarding. premature points pitting. The solution was a 1.8 ballast resistor.. The 087 coil was the match to the resistor which was used later in the 63 model year. My 62 has a replacement 1.8 ballast resistor with a 091 coil and it works just fine.
All ballast resistors and equivalent resistor wires serve the same purpose and are matched to the coil used. Over the years coils and resistors are changed out so that many don't have what GM put there to begin with and most (but not all) of the time it doesn't matter all that much.
I'm not one hundred percent sure which is correct 0.3 or .03 but that's what the GM parts book showed so that's what I typed. I do know the 195174 resistor shows (blue stripe) ( 1.8ohms) so I believe 0.3 probably is correct .
It would be hard to ever detect any "performance" difference with a 1.8 ohm resistor in a high performance engine, but you might notice the points burning faster with the .3 ohm in any setup. I'd run a 1.8 ohm in either one personally.
When making low resistance measurements with a DVM (or any ohm meter for that matter), you need to take into account the resistance of the meter leads. Short the leads together and make note of the reading. Could be zero, could be more, lets say 0.5 ohms. If your ballast measures 2.3 ohms, you need to subtract the meter lead resistance from that measurement so in the example above, 2.3 - 0.5 = 1.8 ohms. Some meters have a function that allows you to zero out the lead resistance while holding the leads together. Non of this takes into account the measurement tolerance of the meter either, but for the purpose of this measurement it shouldn't really matter.
