Pulling rear end
Old Jun 28, 2023 | 06:53 PM
Little67red's Avatar
Little67red
Default Pulling rear end
Getting a lot of vibrations in drive train.Iam hoping it a bad universal joint.but if rear end how hard is it to get out.
Old Jun 28, 2023 | 06:56 PM
66jack's Avatar
66jack
Also, Check all the bushings and the 'snubber' bushing on the front of the diff..
Old Jun 28, 2023 | 07:29 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Can you describe the vibration a little better. Do you feel and hear it in the shifter, the steering, seat of the pants. Tire balance old or new? Look at the u-joints, then look for the balance weight on the driveshaft. Look at the half shaft u-joints. Do they look like there is rust dust at the caps? Dennis
Old Jun 29, 2023 | 07:35 AM
C2Dude's Avatar
C2Dude
If you do have to pull the diff; this is how I did mine. Not a complete step by step. One trick I learned removing the rear spring was to use a "C" clamp on the spring end to prevent the jack from skipping toward the center of the spring. Mine is a 7 leaf and it came apart easily. If under car exhaust like mine, it took some time separating the pipes. After I devolved to the point of beating on the rear pipe to separate it from the front with no joy, I ended up cutting it out and replacing
File Type: docx
Old Jun 29, 2023 | 07:42 AM
C2Dude's Avatar
C2Dude
Pulling the cross member did take about half a dozen wacks with a pickle fork and lump hammer but they did separate. You do want to keep the member bolts loosened but still threaded in so as to "catch" the member once it separates, couldn't hurt to keep a floor jack a 1/2" below it as well, it is a heavy component. Use anti seize on the sombrero joints when reinstalling (I use anti seize on everything applicable when I work on mine). Hopefully you will not need to do any of this but if a snot nosed kid like me can, it's doable.
Old Jun 29, 2023 | 08:19 AM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
The time for removing the crossmember will vary from car to car depending upon its 60-year location. For some, it has taken a lot of time (read: hours); for others, not so long. My suggestion is to use a power hammer. It will unseat the cross member in all of ten seconds.
Old Jun 29, 2023 | 08:22 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
67 Coupe:
My vibration was very frustrating. I checked/replaced the snubber set, strut rods, F41 rear spring (back to factory) wheels (2 new sets), rotors (setting flush), driveshaft angle, raise the floor panel to factory height at exhaust cross member (3/4"), trans mounts (good), engine mounts (good). NO LUCK!
Here is what I'm doing:
Changing out the M21 transmission to Auto, that will remove the pilot bearing all together.
New Balanced flywheel
Balancing the driveshaft
Checking and/or replacing the U-Joints
Replaced front upper and lower control arm bushings. Actually thinking that that could be the issue.
Anything else that could be a potential vibration cause has already been rebuilt. (trailing arms, etc.)
Bottom Line: you might be in for a interesting ride!
As Bluestripe had asked: Where do you feel the vibration? At your feet, in the rear-view mirror, in the seat of your pants,
Old Jun 29, 2023 | 02:21 PM
Little67red
In my hands and feet
Old Jun 29, 2023 | 03:39 PM
Little67red
How about a bad harmonic balancer.did you try to see if was out of balance.
To Pulling rear end
