Harmonic balancer
The flywheel and harmonic balancer were unique to this engine and both carried a counter weight that the other small blocks do not.
Good luck… GUSTO
Sent it to DAMPER DOCTOR in CA. (https://damperdoctor.com/)
He completely repaired mine for $110.00 ('66 327/300) and it looks amazing.
Strongly recommend him for any of your needs in this area; from his website you can see he has many in stock if yours is not salvageable.
Cheers,
Richard
Cheers,
Richard
Damper units that do not carry any addition off-setting counterweight sum incorporated upon the inertia ring, this which may become mispositioned if the ring should turn on the hub, generally will not impart any significant vibration to the assembly until they are notably failed, and is easily identifiable with a casual observation (i.e.: is the inertia ring in place, is the elastomer in place, is the hub fastened tightly to the crank-snout?).
Oh, and do not start or run the engine without the damper properly installed, as it is the preload from the damper snout against the timing gear that maintains the gear in place (aka., without the damper force to hold the timing gear it may just shear the key and then............!) not mention the oil leak.
Scott.
Cheers!
Generally with O.E.M. elastomer type dampers it is best for them to be incorporated in the balancing process; though perhaps in different sequences in the event depending on the intention or whim of the operator. Those dampers which possess an external counter-weight value should be considered as just an extension of the crankshaft and be present from the start; those which are non-counter-weighted or "neutral" are at times treated the same, but in this instance I prefer to "spin" the assembly, balancing the crankshaft without the damper, then add the damper, establish any (the) imbalance, and correct the damper so as it actually does present a "neutral" effect as intended, that as far as in the balancing effect as tested.
B.T.W. the same considerations apply to the flywheels & flexplates (that of the engines applicable in this inquiry).
Some shops will proclaim that in the instances of "neutral" assemblies, they will not require either item, as they are "neutral", and though this sounds reasonable, the addition of these items even though of "neutral" intention, but with inspection will induce an imbalance value; as just realize, as hard as we try nothing is "perfect", but if one tries hard enough you 'can' make it better!
Now, there are exceptions, for example, some dampers (and flywheels), as engineered, are not to be incorporated in the balancing process; this generally having something to do with manor in which the inertia ring mass is located and whether from a resting state and transitioning to the state as experienced in the balancing process, will it present itself as located as on the engine in it's functioning state.
Scott.
Cheers,
Richard
He did tell me on the phone that depending on what it was when he got it, it could be a lot more because there are, evidently, rarer ones out there. Evidently you have one of those! I try to keep the car as original as possible even though it is a driver and never a show car. However, if mine had been that much, I believe I would have searched for an option!
Hope you get yours done without the higher expense!
Cheers!
