[C1] steering Column install
Old Jun 30, 2023 | 09:21 PM
blackvette7661's Avatar
blackvette7661
Default steering Column install
I am going to install the body on the frame, all driveline is in the frame. What process is involved in getting the steering Column in???? Can it be dropped in after the body is sitting on the frame??? There is no interior in the car, and it has headers on the motor.
Old Jun 30, 2023 | 09:40 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
C1 or C2?
Old Jun 30, 2023 | 09:48 PM
blackvette7661
1961-c-1
Old Jul 1, 2023 | 12:55 AM
silver837's Avatar
silver837
Your first try ? It takes some finesse . The people who really know will help you through it
Old Jul 1, 2023 | 08:56 AM
jforb's Avatar
jforb
I installed mine (1962) after getting the dash put together, it was easy to install the steering box/column then and it was out of the way while doing all the other work.
Old Jul 1, 2023 | 09:56 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
Put the column in BEFORE you drop the body
Old Jul 1, 2023 | 10:09 AM
ptjsk's Avatar
ptjsk
As csherman has stated, the steering column is installed prior to body drop.
Pat
Old Jul 1, 2023 | 10:46 AM
jforb's Avatar
jforb
I'm confused...why would you install it before installing the body? Because that's how they did it on the assembly line? I'm just trying to understand why you'd do things the hard way.
Old Jul 1, 2023 | 10:55 AM
wilbur's Avatar
wilbur
I agree. I had no problems installing my steering column with the body on. Not sure why you would install like suggested ???
Old Jul 1, 2023 | 11:31 AM
OC-1's Avatar
OC-1
diff between 57 style column and later columns. 57 might be best to install column first , later can be finessed w body on... as i recall
Old Jul 1, 2023 | 01:15 PM
jforb's Avatar
jforb
Through 1962 the column and steering gearbox are one piece. Starting 63 they're separate. I can understand installing the column first in a 63-later car.
Old Jul 1, 2023 | 01:44 PM
csherman's Avatar
csherman
So quick I will explain - The 53 54 55 MUST go in before body drop - the hole in the firewall is just big enough for the column - plus you have to push SOOO hard on the inner fender to get it in and you will scratch the inner fender and scratch the column - There is NO WAY to get the column in - NO WAY
- In 56 they made the hole bigger on the firewall and covered it with a plate (plate has to go on the column first before you install the column) - so you can get a better angle to get the column in - then the plate covers the huge hole / It is much easier to get the columns in with body off the frame- also the columns are shorter than 53 54 55
- The only exception is if the motor is out of the car - if the motor is out - the column comes thru the grill oval and core support and be installed with the body on the frame.
- on a 56 up with the motor in the car - the LH exhaust manifold has to come off and the LH generator if it has one on the left side - its not about doing things the hard way - it is actually easier and cleaner - its about what's needed to do in order..... I just installed a column in a 54 and we are dropping th body on the 6th - hope this helps - Chris TiN Restorations
Old Jul 1, 2023 | 01:52 PM
csherman's Avatar
csherman
Old Jul 1, 2023 | 02:06 PM
Dan Hampton
Correct. I substituted a '62 steering unit in my '57 to take advantage of the shorter column (2") and it was very difficult to get in and out with the body on. The exchange of the column was in concert with a complete rewiring of the car. The '57 column has to enter and exit through a hole in the dash, which gives you no ability to flex the column upward.
Old Jul 1, 2023 | 05:27 PM
C.T.'s Avatar
C.T.
Here's a prior thread, some repetition, but not all.
https://www.corvetteforum.com/forums...n-removal.html
Old Jul 2, 2023 | 02:41 PM
dmtparker's Avatar
dmtparker
I removed and reinstalled the steering column/box in the 62 without disturbing the body. Not real easy, but I did it myself without help.
Old Jul 2, 2023 | 05:29 PM
C.T.'s Avatar
C.T.
Same here with my 57, but these (56 and up) have the larger firewall hole that lets you angle the column around as csherman points out.
To steering Column install
