Alternator charging of battery diagnosis
Received 1,584 Likes
I have a 10DN 35 amp alternator, electronic voltage regulator, and 1 year old battery holding 12.54 vdc at rest. The ignition system is a Chrysler magnetic reluctor pickup and amplifier box with a 1.3 ohm ballast resistor.
While troubleshooting an ignition electrical problem, I put volt meters on the battery and ignition point side of the ballast resistor.
At idle, the alternator is charging at the battery 13.9 vdc +/- and at the ballast resistor (negative side of coil) 9.3 vdc +/-.
While driving the car, above 1000 rpm, the the alternator is charging at the battery 14.1 vdc +/- and at the ballast resistor 10.5 vdc to 11.1 vdc +/-.
The readings are taken with only the radio and ignition system drawing a load during driving, and of course the brake lights occasionally.
I was expecting the voltage reading from the alternator to decrease as the alternator charges the battery after starting the car, however, it does not seem to change after a 1 hour cruise at various speeds it remains constant at ~14.1 vdc. The battery returns to 12.5 vdc +/- after normalizing for more than an hour or so with no load.
Am I wrong in my expectations to see the alternator fluctuate charge of the battery like the voltage meter on a battery charger?
I am concerned the battery may be failing or I still have a short causing a constant draw and alternator charging.
Thanks,
Ron
Thanks,
Ron
Received 6,664 Likes
C2 of Year Finalist (track prepared) 2019
You are concerned that the alternator output doesn't drop to a maintenance Voltage after the battery is fully charged? Am I reading that correctly?
Assuming so, my observation is that lowering the output Voltage to a maintenance level isn't a universal trait of charging systems and almost certainly not a trait of older, dumb alternators. The dumb alternator of my 2004 2500 Dodge truck puts out 14.0 - 14.2 V continuously, for example. The charging system in my 2017 travel trailer, in contrast, does reduce the Voltage to the batteries once they are fully charged. Of course, that's not an alternator; it's a smart charging system.
Anyway, my point is that I don't think anything is wrong with your 10DN-based charging system.
leif.anderson93 (08-09-2023)
Don't want to have a "Tow of Shame" on a flatbed again, it has made me paranoid I guess.
Thanks Gentlemen,
Ron
That's interesting. I just changed my battery and checked my charging voltages to insure my alternator was functioning properly. Statically, engine not running, I have a battery voltage of 12.88 V. Starting engine at idle @ 650RPM, voltage doesn't change much until RPM hits 700-800 then voltage starts rising to 13.5, 13.8, and up to 14.8 at over 1,000 RPM. It settles to around 14.6 - 14.8 and RPM's over 1,000. This is with no load on the system. I have the original 37 amp alternator with the mechanical regulator. I've never had any charging problems and the last battery lasted 7 years. What R66 mentioned above, I don't think the old mechanical regulators do hold voltage steady like the new electronic types do, based on my results.
Received 2,170 Likes
2015 C2 of the Year Finalist
... I was expecting the voltage reading from the alternator to decrease as the alternator charges the battery after starting the car, however, it does not seem to change after a 1 hour cruise at various speeds it remains constant at ~14.1 vdc.
Thanks,
Ron
Thanks,
Ron
Dan
