[C2] FI help
Popular Reply
John DeGregory, one of the nicest and most honest people you'll ever meet, is the only rebuilder I know of who was factory trained(!) on FI. He's been doing FI units longer than anyone. I'm pretty sure he did the FI unit on Ben Hur's chariot.
You did not state what model injectors you had or distributor, there should be a model ID tag on the air meter side.
I would do a quick inspection of the distributor gearbox by removing the model plate secured with 4 screws. If the gears have a brass color probably OK if dark or black it was starved for oil sometime in the past.
John DeGregory is a longtime FI specialist is located in Greensburg, Pennsylvania (724) 832-3786
Jim Lockwood is a forum member and is in northern California is an FI expert, contact him via PM.
Lyle Davidson is probably the youngest of the ones listed and reproduces the 63-65 plenum lid and the fuel meter cover. Lyle Davidson is located in Leesburg Virginia 571-224-8830
Futo and Son is located in Scottsdale Arizona, Futo and Son Website
Gary Hodges is located in Salem Oregon Gary Hodges Website
Ken Hanson is located in Medina Tennesse
Jerry Bramlett retired and is no longer available.
If your unit is in need of an axial link, I would source one from Frank Antonicelli. The phone numbers I have listed are old and may no longer be valid.
Whoever you choose be sure to ask if they do an on car running driving test.
*or*
Can someone get me a measurement of there's, say from the mounting surface to the top of the cap??
Thanks in advance!
It can be done .
