Spark plugs
Old Sep 12, 2023 | 10:54 PM
Little67red's Avatar
Little67red
Default Spark plugs
I have a 406 10-1 compression afr head’s Holly carb 770cfm. Running ac 41-628 plugs.they run rich black no matter what I do.what plugs are you running.do I need to go hotter on the plugs.if so what is the number.
Old Sep 12, 2023 | 11:58 PM
Vette5311's Avatar
Vette5311
I doubt just changing the plugs is going to do it. Check carb power valve for rupture, or even better, swap on a known good carb borrowed from a friend.
Old Sep 13, 2023 | 01:34 AM
belgiumbarry's Avatar
belgiumbarry
had the same problem on my 10.5 :1 Merlin 540.... so i installed a AFR gauge . ( Innovate ) Then you see at least what's happening.
Running to rich , i overhauled the carbs ( tripower here ) with new gaskets and power valve., AFR is fine now , idle around 15 , driving 12...13
And new plug wires , measured them at 15 K Ohm... new MSD set is at 150 Ohm ! Was a big improvement in driving. Must have given "weak" ignition . ( had already new HEI distributor)
I use Accel 6 plugs , don't know what's the heat range compared your AC plugs. But must test drive it more to see if they are not to "hot" plugs.
Old Sep 13, 2023 | 07:06 AM
Chalie M's Avatar
Chalie M
Thought I knew a little about reading spark plugs:-).. man did this video open my eye’s..
* Interesting on how to read/get timing info off of the ground strap on the spark plug*
https://garage.grumpysperformance.co...ng-plugs.5428/
(Steve Morris has some very interesting video’s)
Good Luck
Chalie
Old Sep 13, 2023 | 08:01 AM
belgiumbarry
sorry if i'm wrong , but i think a ac 41 is a "cold" plug. Don't stock SBC use ac 45 ? i found my Accel 6 are in the range of ac 43...44
To Spark plugs
