1965 stock 327/350 4 speed Muncie just had the clutch replaced by a mechanic with a LUK. After 2 weeks of normal driving clutch is working fine with the exception of a spinning / scraping sound with foot off the clutch when idling in neutral.
the mechanic tried adjusting it, which didn't help. The flywheel was resurfaced during the clutch replacement. Also feel some slight vibration when depressing the clutch pedal at times.
Going back to the mechanic tomorrow. Any thoughts on what might have happened?
Did your mechanic use the adjustable throw out (release) bearing? As I recall, I had to pre-adjust the bearing that came with the LUK kit. Just something to check along with correct installation of the bearing on the clutch fork.
If noise is only heard with your foot off the pedal and if there is a correct amount of free play in the linkage, would not the T/O bearing be sitting idle on the Muncie input shaft retainer? Would almost think what ever is spinning within the transmission while in neutral may be where it is coming from.
Make sure the inspection plate in front of the bell housing is not hitting the spinning flywheel
If the correct pedal freeplay is there, then the TO bearing is not spinning with the pedal at the top. Rules the TOB out.
I agree with tbarb here, where there is a chance the cover plate didn't get installed correctly, thereby touching the flywheel. Take it off and see if the noise is gone, then reinstall - paying attention to where it "engages" on the oil pan lip.
This is definitely worth looking into. I let him know. Thanks
When it is idling in neutral - foot off the pedal - and the noise is there; kneel down beside the car and use you hand to slowly depress the clutch pedal.
Did the noise change at all from the pedal all the way out - to where you can feel the TOB contacting the pressure plate (resistance)?
A weak or broken spring on the clutch fork at the ball or a incorrectly installed throw-out (release) bearing may still be lightly touching the pressure plate even with an inch of free play at the pedal. An inch at the pedal pad is probably less than 1/4" of movement at the bell crank and then the loss at the clutch fork ratio from the rod to the centerline of the input shaft. It might be interesting to calculate the movement at the throw-out (release) bearing you actually get with 1 inch of free play in the pedal.
When you pull up on the pedal with the engine running, does the noise go away or change?
I just replaced my clutch with a Mcload unit and their adjustable T/O bearing as the flywheel they sold me was thinner than the iron one I removed, 2 years back. On mine, after adjusting the linkage for free play I can kneel aside the car, engine off, grab the clutch pedal in my hand and push until the bearing makes contact with the PP. There is an audible "clink" when it does that. That, I would think, confirms that there is no contact when the pedal is released, therefore it is not spinning when the motor is on. With that in mind I do not see how it can be making noise. If the inspection plate were contacting the back of the flywheel, it would be making noise constantly regardless of clutch position. Yours is not installed so it's not that. Still thinking it may be the Muncie.
The throwout bearing was replaced with a differnt type which appears to have resolved the issue. In addition, the linkage to the clutch pedal was adjusted to tighten things up and make the pedal travel more smoothly.
Don’t forget about the two anti rattle springs on the linkage. Without them you will get all kinds of strange noises.
That's excellent advice, thank you for that. And thank you to everyone for responding to my questions. So much great information is being shared on these forums.
