[C2] C2 frame differences
Old Sep 22, 2023 | 10:24 AM
ettev's Avatar
ettev
Default C2 frame differences
So learning the hard way there are a few difference between a 63 frame and the 64-7 frames. Can someone tell me the exact differences and why they changed the items after one year?
Old Sep 22, 2023 | 10:29 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
63 had solid body mounts thus a higher body mount frame perches. Plus I think the parking brake cable mounting to the frame is one year only. And each year after had subtitle parking brake mounting differences plus other things
Old Sep 22, 2023 | 10:39 AM
ettev's Avatar
ettev
Thanks Keith.
are the mounts made taller and welded on the frame in the same location or are the mounts the same for all years and welded to a different height on the frame?
Old Sep 22, 2023 | 10:43 AM
Nowhere Man
They are all on the same location each year.
walleyfisher's Avatar
walleyfisher
Originally Posted by ettev
Thanks Keith.
all body mount locations are the same, except the heigth if the body mounts on the '63 is higher and the '63 and '64 have an additional set of (2) body mount inboard by the drive shaft tunnel and use rubber bushings also on the '63 the holes in the body mounts are smaller than all the rest of the years
Old Sep 22, 2023 | 10:47 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Early 64 had no mid rail Chassis gussets. All 64's had no center and outside seat cables, and NO FORWARD BB indent
All those features started in 65
Old Sep 22, 2023 | 11:12 AM
68sixspeed's Avatar
68sixspeed
St. Jude 15 Year Donor
St. Jude Donor '10 thru '26
also no slots for side pipe mounts on 63 or the reinforcement at the back of the side frame rails in front of the rear tires. Also the seat belts are only attached to the body, on 63 and I think 64, no connection to the frame.
Old Sep 22, 2023 | 12:27 PM
jrm5657's Avatar
jrm5657
2022 C2 of the Year Finalist - Modified
Everything stated so far is correct. 67 has different parking brake cable settup using a pulley since lever is mounted between seats. Long front to rear brake line routing is a significant change as 66 and 67 moved to lower inside edge that can actually be changed out without lifting body, while early frames the line is mounted on top and impossible to get to with body bolted down.
Old Sep 22, 2023 | 12:35 PM
Vitaminmopar's Avatar
Vitaminmopar
This forum write up from the past on frame differences, also check for cracks at the welds referenced in this thread Weld Check on Frame
Old Sep 22, 2023 | 12:51 PM
gleninsandiego's Avatar
gleninsandiego
Wow - that is a fantastic write up
To C2 frame differences
