[C2] Battery Hold Down Question
Old Sep 25, 2023 | 11:11 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Battery Hold Down Question
Hello forum,
I have a March of 1965 built convertible no air conditioning.
I see 2 different battery hold downs listed with the various vendors.
One has an attached heat shield and the other does not.
My question is what was originally installed?
Thank you,
Marshal
Old Sep 25, 2023 | 12:04 PM
Vet65te's Avatar
Vet65te
Marshal - The non A/C cars had the battery hold-down with the heat shield for the passenger side mounted tray. The A/C cars and 65 L78s had the battery on the drivers side and were
far enough away from the exhaust system to not require a heat shield as part of the hold down assembly.
Mike T - Prescott AZ
Old Sep 25, 2023 | 12:07 PM
marshal135's Avatar
marshal135
Mike T,
Thank you, Sir, for the prompt response.
Now I know which one to purchase.
Marshal
Old Sep 25, 2023 | 01:28 PM
marshal135's Avatar
marshal135
Mike,
post thought… will it fit with a group 34 battery?
I hope it is a drop in part.
Marshal
Old Sep 25, 2023 | 01:41 PM
OC-1's Avatar
OC-1
group 24?
Old Sep 25, 2023 | 02:09 PM
leif.anderson93's Avatar
leif.anderson93
Originally Posted by marshal135
Mike,
Marshal
Group 34 is the same width and length as a Group 24 (stock size battery)...however, it is one inch shorter in height. It will fit in the tray correctly, but I don't know if the hold down will work (not that familiar with '65 hold down bracket)
Old Sep 25, 2023 | 02:17 PM
Vet65te's Avatar
Vet65te
Hey Marshal - Yes indeed, the Group 34 batteries will fit and that's my preference over the original Group 24 batteries because 34s are a bit shorter and, at least to me, a bit easier to
wrangle into place. The Group 24's are roughly 8 7/8 inches tall, the Group 34's are 7 7/8 inches tall. I use the 34s in all my midyears.
To Battery Hold Down Question
