Engine Identification help
Old Oct 21, 2023 | 04:56 PM
dgolds55's Avatar
dgolds55
Default Engine Identification help
I have the potential of getting a Corvette engine for a have the potential of getting a Corvette engine for a 1957 fuel injection. The numbers are:
Engine Casting-3731548
Deck- F927EL
Distributor- 1110905 7A17
Cylinder Head- 3731539
Fuel injection-Rochester 7014360
Does anyone know if these are matching numbers for the 283/283 or what other information I need to do some verification that this engine goes with the car?
The Vin number is E57S100293
thanks in advance for any help!
Old Oct 21, 2023 | 05:02 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
It all fits.
Old Oct 21, 2023 | 05:08 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
what is the casting date? any pictures of the stamp pad. just because the numbers are correct doesn't mean the engine was not restamped after it left the Flint factory
Old Oct 21, 2023 | 05:33 PM
dgolds55's Avatar
dgolds55
Where do I find the casting date on the engine?
Old Oct 21, 2023 | 05:34 PM
Nowhere Man
The opposite side of where you found the casting number
Old Oct 27, 2023 | 03:03 PM
dgolds55's Avatar
dgolds55
Default Casting Date Found
The final number I needed is the casting date which is I276. If I understand correctly how to decode this the I stands for the ninth month of the year the 27th is the date and the sixth is the year thus the engine casting date is September 27, 1956. That matches the block date of September 29, 1956 in my best estimation of the build date is around October 10 based on the Vin number. Is there anything I’m missing?
Old Oct 28, 2023 | 11:16 AM
rsinor's Avatar
rsinor
This is obviously a rebuilt motor or at least cosmetically redone. You should post a picture of the engine pad where you got the engine code from. As mentioned just having numbers on it does not guarantee they are GM/UAW work.
To Engine Identification help
By Michael S. Palmer | 2026-06-03 09:39:05
