Intake/Carb Question
Many of you are familiar with dual quad set-ups. There is probably no question this 350 c.i. is over carbed with two 600 cfm Edelbrock carbs, but I've been told we should be able to get a decent tune on it. I was doing some research on the topic on the web, and came accross someone who had a tunnel ram dual quad setup and was only running one carb!!! This seemed weird to me, but if you think about it, you just tune one carb, but get the unbeatable :cool: looks of dual quads.
As usual, it takes me awhile to get to my actual question, but here it is. With this "cross ram" type dual quad setup like you see pictured below, can we run just one carb?? Someone told me a long time ago the left carb "crosses over" and feeds the right four cylinders, and the right carb vice versa. It's been 10 years since we've had the intake off the car for me to look up inside the intake to see exactly what is going on up in there. I have no idea if this is true, or if each carb actually feeds the entire engine. Seems pretty risky to me to have an intake designed like that where one carb runs one side of the engine. Is anyone familiar with this intake and how it works?? It's an old Edelbrock piece. I think the number on it is "X something". Here's a picture of it.
The body is currently off the frame. I "boxed" in the frame rails last weekend to gain some strength in the frame. A 60 year old Model A frame wasn't designed to hold 350 horsepower!!!
Any advice would be really appreciated. It would make my job of getting a good tune on the car for the strip much, much, easier if I can run just one carb. We have the engine out, and I could post a close-up picture of the intake/carb setup if it helps. Thanks, Brian
[Modified by Brian Matheis, 8:46 AM 1/23/2003]
If so, and I suspect it is, you will probably need to tune the carbs exactly the same. If you are having difficulty tuning, I'd suggest you rebuild both carbs, ensuring that the same size jets, same adjustments on the butterflies, etc are used. Start off with the idle screws backed out the same amount (say, 1 turn), and after installing them and warming up the engine, make all adjustments equally to both carbs, ie, each time you tweak an adjustment on one carb, make the exact same adjustment to the other before deciding whether to make another (pair of) adjustment(s).
:cheers:
[Modified by INMYBLOOD, 1:08 PM 1/23/2003]
[Modified by Kid_Again, 3:47 PM 1/23/2003]
Wayne, The carbs are brand new Edelbrock. For tuning purposes we would have rather gone with Holleys, but we would have had to "engineer" a whole new linkage setup.
John, I suspect you are right about each carb feeding the entire engine. It'll be pretty easy to figure out once we plop the engine back in. I'll just unhook the linkage from one of the carbs for a minute and see if the thing acts like it
s running on 4 cylinders!!
The key to bracket racing is consistency on your time, and cutting a good light. It's not like we're going racing every single weekend and trying to vie for the points championship at the track or anything, but I do want to get a good tune. That's why the "only running on one carb" idea sounded pretty good to me. Seems like it could be more cosistent that way too.
David, I remember that article now that you mention it. I subscribe to Hot Rod, and I'm pretty sure it was in there. You jogged my memory on it. In fact, I think I remember telling Dad about it. When I get home I'll dig through my stack of old magazines and see if I can find it.
Thanks again guys, Brian
I guess I trust this guy?? I may still try to run the engine on one carb when we get to that point. Thanks again, Brian
:cheers:
