Press Mold Or Handlayed Fiberglass For a Restomod?
Great Thread! I've been thinking about getting a new nose for my 58, since the one I have needs a lot of work. It appears to be original but apparently been hit at some point in it's life. I was really considering a one piece HL from CI, but now I'm wondering if I should go PM. It's going to be my car and not one I'm building to flip, so there's that. I will continue to follow this thread and make a decision later, not in a real big hurry.
Dex.
Dex.
- I would not hesitate to use the CI one-peice HL again. No question. The other 2 vendors I got a 62 nose from.... nope... no way
- Extra work; The one-piece will be more work to install. It does not have the inner fenders, splash pan, etc, all built out.
- The fact that the nose is not built out also has a blessing to it. One has more control over adjusting the top of fender height to match with the hood height. One does this in part by adjusting the upward pressure one allows the inner fenders to 'push up' on the inside of the hood ledge on the top of the fender. If one is unsure how all those 'hits' over time torqued things around a bit, one may need this flexibility (as I did) to control how much 'push up' (or down) one exerts on the bottom of the hood ledge on the fender at different points along that hood ledge. As a result, my hood height / fender height levels, and hood gap around the hood opening is near perfect.
- Authenticity; The original nose is already gone, so it is no longer 'original' anyway... be it a HL or PM one installs
- As noted, to make it look a little more 'authentic', with the added benefit of some added rigidity, I added some bonding strips to the one-piece nose. Cheap enough and only takes a few minutes to bond them in.
Either way.. I doubt very much my 62 will see any 'gaffs' over time because I used quote 'a cheap' HL. In fact, I feel just the opposite. Last... 99.9% of the public would never know the diff if I should ever go to sell the car... if it is a PM or One-Piece nose.
Hope this gives some more food for thought.
58n65 (11-19-2023)
Those are good points. It's important to bear in mind that although press mold is used in industry, a skilled craftsman can produce equal or better results by hand, The time/wage equation is not a factor outside of the work place, and many times a press mold (like the ones I played with) produces "good enough" results....it all depends on what the acceptance criteria are, and if a flaw is in the mold...it is in everything made by the mold. So, hand labor is almost always present anyway.
But I still wouldn't want to lay it up....what a messy smelly PITA that can be.
Everyone knows that CI or Corvette Image is no longer the same company, the same people, or the same location? I would be happy to share the details of a recent experience privately..Over the last 40 years I have glued together more cars than I can remember. I like to think we know what we are doing and what to look for in quality parts.
Has anyone ever heard of this company? - Corvette, Front End, 1958-1962 – American Sports Car
Closed its doors recently
58n65 (11-28-2023)
Tether Man
Received 2,038 Likes
2019 C1 of Year Finalist (appearance mods)
I ended up with a PM Front Clip and BB Hood from Coffman Corvettes. I was told by my meticulous Corvette Builder in Erie Pa. that they were near perfect panels. My Panels were possibly the earliest produced panel out of Ohio. So they may have been pressed by former Employees of CI. I do not know. I do know that employee(s) came to Ohio with the equipment. Maybe I got lucky!
I would like to hear what you have to say!!
Isn't this a one piece install by NCRS members?
Received 1,483 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
Pressmolded all day long
If your building a high end resto mod - as a builder, as a shop and as an owner
Hand laid = cheap
If you went cheap on the body - what else did you cheap out on ?????
Hand laid / chopper gun parts are inconsistent in thickness
They are easier and cheaper to make and they look it from the under side - rough with glass strands everwhere
I just ripped off a hand laid nose and installing a PM nose
I dont use hand laid parts and I wont install them
Cheap looks cheap
Chris
TiN Restorations
Plano IL
Hand laid = cheap
Cheap looks cheap
Chris
TiN Restorations
Plano IL
I will say this:
One of the employees that worked for Corvette Image - moved to Ohio and is the assembler for Coffman - I dont know the person but was told by Lori and Jerry that he is very good at what he does
I recieved a PM nose for a 54 we are doing and quality is the same at what it was in Oregon.
Chris
TiN Restorations
#33
Hand laid = cheap
Cheap looks cheap
Chris
TiN Restorations
Plano IL
Hand laid = cheap
Cheap looks cheap
Chris
TiN Restorations
Plano IL
#35
Note; I see a bit of discussion about 'chopper guns' above in the same breath as 'Hand Layed'. 'Hand Layed' glass weave or mat into a comparatively structurally very strong, seamless, homogenous one-piece nose, verse el'-cheapo 'Chopper Gun blown' fiberglass strands into a mold are not even close to being the same product. Be it a Corvette nose, a boat hull, a fiberglass part, etc, people should not use the terms interchangeably, or understand them to be, and most important... understand (insist on knowing prior to purchase) what one will be getting as a construction method.
#36
