[C2] Rear Diff Fill Plug Gasket Type
Old Nov 16, 2023 | 05:25 PM
vetterss's Avatar
vetterss
Default Rear Diff Fill Plug Gasket Type
Well, I was working on my '64 rear diff to change the fluid and when I broke the fill plug loose to pump out the fluid, a piece of the flange cracked off. (not internally) So I ordered a replacement and it comes with a leather I think original type gasket. For the NCRS guys out there or anyone, do these work or do they leak? This is a driver car. I also ordered a copper gasket as well. Let me know your thoughts, thanks.
Old Nov 16, 2023 | 06:20 PM
GTR1999's Avatar
GTR1999
The 63-4 Diff covers had a steel vent and 1"-20 machine plug. They were both replaced by 1965. The plug came with a leather flat washer, seal. They didn't work too good. The machine threads would wick the oil out and why in 1965 they changed to a 3/4 npt plug. You can try teflon tape or make a seal and see if it works.
Old Nov 16, 2023 | 06:49 PM
SupremeDeluxe's Avatar
SupremeDeluxe
I’m dense, so I wasn’t aware of the 63-64 using the leather seal until this summer when I, too, found a cracked plug flange.
I got a new plug and gasket from CC—the threads were machined wrong. Took me a bit to find a used plug and the leather seal works fine.
Old Nov 16, 2023 | 08:56 PM
R66's Avatar
R66
If you use teflon tape or dope on the threads, get the yellow which is made to resist petroleum products, the white will dissolve over time is what they claim.
Old Nov 17, 2023 | 09:16 AM
tbarb's Avatar
tbarb
How about some permatex #2 on the threads then the gasket.
Old Nov 17, 2023 | 10:03 AM
68sixspeed's Avatar
68sixspeed
St. Jude 15 Year Donor
St. Jude Donor '10 thru '26
I've had good luck with Permatex gear-oil rtv,
Amazon Amazon
Old Nov 17, 2023 | 07:59 PM
GTR1999's Avatar
GTR1999
https://www.amazon.com/Permatex-8118...98&sr=8-2&th=1
That is the best to use
To Rear Diff Fill Plug Gasket Type
