61 Bubble
Old Nov 17, 2023 | 06:00 PM
Eric Sakai's Avatar
Eric Sakai
Default 61 Bubble
Friend got 61 to Hawaii, bought Florida.
what cause of bubble?
is the metal rust under fiberglass or something else?
Thanks in advance,
eric0
Old Nov 17, 2023 | 06:30 PM
ChrisBlair's Avatar
ChrisBlair
I can't say for sure what's under that paint all these years after the car was built, of course, But steel? I don't think so.
Might be resin-rich spots
Beautiful car by the way. A couple bubbles doesn't change that.
Old Nov 17, 2023 | 07:45 PM
SupremeDeluxe's Avatar
SupremeDeluxe
I am guessing this is the car:
https://www.corvetteforum.com/forums...nvertible.html
The paint is over 40 years old, so not surprising there would be imperfections. I see these bubbles in the seller's photos as well. It looks like contamination below the paint that caused an adhesion problem in that spot.
Old Nov 17, 2023 | 10:04 PM
John S 1961's Avatar
John S 1961
Delamination caused by a non compatible substrate.in a localized area.
Old Nov 18, 2023 | 12:31 AM
silver837's Avatar
silver837
If the substrate had a concentration of solvent and you add hot sunlight you get a bubble .
Old Nov 18, 2023 | 06:55 PM
MarvBarrish's Avatar
MarvBarrish
I've had this problem before as well. While there is no real solution for the issue of the bubbles other than repainting. I stuck a pin in the bubbles and massaged gently the air inside the bubbles out. It worked. The bubbles relaxed and laid down and stayed down. You could see the pin hole only if you looked for them. This could be labeled a bubba fix but can work until you're ready to repaint the car. Good luck. Marv
To 61 Bubble
