I am reinstalling the trailing arms in my 67. There are no holes in the frame for the cotter pins that I believe are to make shim adjustments easier. I am not sure it is possible, but is it worth it to drill the holes? If so, I assume the align with the second big hole in the shims? Thanks!
The shims changed in about 69 or 70. The newer style shims make a tough job of aligning a bit easier. The newer style slip in as opposed to the pivot bolt going through them. If your car is not to be judged, consider using the newer style shims and drilling a hole to capture the shims at the bottom of the frame pocket. I drilled a hole and use a black zip tie to keep the shims in place. Works for me and my alignment guy. Jerry
Get a set of 1963 "tongue" shape shims. The tip of the tongue rests below the lip on the frame opening so the shims can't work their way out. No holes needed.
Jerry, once I learned it was a C3 thing, I searched for it and found what I needed. It is at a bit of an angle, but I was able to drill one side tonight, in just a few min. Should make the whole process easier. Particularly if I do the alignment myself. Thanks for your help.
how many times do you plan on removing them? It's not that big of a deal to do it correctly the first time
I have to agree with Keith on this one. As much as most drive these cars (which isn't very much) doing a correct alignment may be a once in a lifetime preposition...barring any damage due to road conditions or accident.
I've written this before but I will do so again. Buy both the correct set of shims and a set of slotted shims. Find a competent alignment shop (harder to do than the alignment itself). Have them do the alignment using the slotted shims because it is "easier" for them, thus being less expensive for you. When you get the car home, count the number and thickness of each shim on each side of the trailing arms. Remove the trailing arm bolt, remove the slotted shims and replace with the correct shims with the holes in each end (same number and thickness as the slotted shims that you removed), reinsert the bolt and nut and tighten down, insert cotter key...and, you're done. Many miles of happy, trouble free driving without drilling holes in your chassis and worrying about slotted shims falling out...been there, done that.
JMHO, of course, but it works for me.
