[C2] Front Spindle Diameter
Old Nov 25, 2023 | 03:29 PM
3154tm's Avatar
3154tm
Default Front Spindle Diameter
I'm replacing the front wheel bearings on a '67 and noticed that the inner bearing is an easy slip fit on the spindle. seems a little to easy. measuring the spindle diameter i get a approximately 1.252". close enough? the spindle doesn't evidence any over heating at the bearing mating surface, that is, it isn't blue or burnt looking. thanks.
Old Nov 25, 2023 | 10:32 PM
DansYellow66's Avatar
DansYellow66
I think spec is 1.25” dia so you should be OK. It’s not an interference fit but it shouldn’t be loose either.
