[C1] 61 No Start
Old Nov 26, 2023 | 06:17 PM
Eric Sakai's Avatar
Eric Sakai
Default 61 No Start
New post again, for friends new 61.
At gas station car could not start, no sound.
What could this be? Starter solenoid?
usually you get warning sounds.
Thanks in advance.
Old Nov 26, 2023 | 06:22 PM
John S 1961's Avatar
John S 1961
Describe the drive to where it stalled. Seemed normal? Start good at home? Run good?
Old Nov 26, 2023 | 07:04 PM
Eric Sakai's Avatar
Eric Sakai
From before engine sounded little ruff but could start and run. New owner reports lot of carbon on ground from exhaust.
Now, stuck at gas station mechanic reports fuse for battery burnt.
what does this mean now, short in wires?
20 years ago I changed all wires on my 58 because of spliced wires.
Old Nov 26, 2023 | 08:35 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Fuse for battery burnt !!!! I call BS. Sounds like a loose or dirty connection.
Pretty car.
Old Nov 26, 2023 | 08:47 PM
R66's Avatar
R66
FUSE FOR THE BATTERY??? Must have been added if there is one.
First, clean the battery terminals. Check for headlights and horn indicating the battery has a charge.
Second, try jumping the solenoid from the battery terminal to the S terminal with a screw driver. (use an old screw driver as it will burn it if the battery is good).
If the engine turns over with the starter, but will not start and have fuel at the carburetor, then you get into checking the points, condenser, coil, resistor wire, coil wire, etc.
You can try a 12ga jumper wire from the positive side of the coil to the positive battery post if you want to hot wire it temporarily for a short drive home (10 miles or so).
Old Nov 26, 2023 | 10:41 PM
Eric Sakai's Avatar
Eric Sakai
Thanks, “Pop Chevy” probably right.
gas station guy said battery terminal and starter was loose.
friend got his car able to start, and got car home.
I told friend to start up car everyday to see if there is a short that develops.
To 61 No Start
