Please help with plug gapping ('59)
Old Jan 25, 2003 | 05:51 PM
6spdNavy99's Avatar
6spdNavy99
Default Please help with plug gapping ('59)
Decided to tune up the '59 Vette this weekend. Can someone tell me the proper sparkplug gap for a '59 283/230? Thanks for your help.
Old Jan 25, 2003 | 07:23 PM
Plasticman's Avatar
Plasticman
Default Re: Please help with plug gapping (6spdNavy99)
.035" is the correct gap.
Old Jan 25, 2003 | 08:00 PM
6spdNavy99's Avatar
6spdNavy99
Default Re: Please help with plug gapping (Plasticman)
Thanks for the info!! :cheers:
I am off to the garage.
Old Jan 26, 2003 | 11:55 AM
62fuelie's Avatar
62fuelie
In addition to the .035 gap, here is some more pertainent info: Most plugs come from the factory with the proper gap, so most simply need a verification that they are correct. If you run into one that is off and you have to bend the side electrode to get it within spec, be sure the side electrode is roughly parallel to the center electrode. If it is at an angle, you may be measuring the gap only to the tip and not to the flat part of the electrode.
To Please help with plug gapping ('59)
