[C2] Vacuum leak
Old Jan 13, 2024 | 04:57 PM
prestige6's Avatar
prestige6
Default Vacuum leak
What is the best way to check for a intake vacuum leak. I hooked up a vacuum gauge to the intake and it is way off the scale
Old Jan 13, 2024 | 05:09 PM
TAlvarez's Avatar
TAlvarez
I usually use WD40 and spray it where the intake manifold mates to the head. Also around the base of the carburetor. If it's leaking, you'll see it suck the WD40 in. Also, you should check all of your rubber vacuum hoses. May have one that is broken or cracked.
Ted
Old Jan 13, 2024 | 05:32 PM
Tampa Jerry's Avatar
Tampa Jerry
The best way to find a leak is with a smoke machine. A good mechanic will have one. You can also use a propane torch around the usual spots. If the idle goes up, you have found the leak. Did the leak come on quickly? Do you have AC, PB, Auto transmission? Disconnect them all and plug the vacuum lines to the manifold fitting. Is it possible some of your cam lobes went bad? Jerry
Old Jan 13, 2024 | 06:13 PM
66jack's Avatar
66jack
Just don't do it 'lit'..
Old Jan 13, 2024 | 06:22 PM
leif.anderson93's Avatar
leif.anderson93
What were your readings in Hg?
Old Jan 13, 2024 | 06:50 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Yeah, "off the scale" doesn't make sense. The maximum vacuum for an engine is about 22 in/Hg with the vac gauges scaled from 0-30. A "perfect" vacuum (unobtainable in real life atmospheric conditions) would be 29.92 in/Hg while most stock engines run about 18-20. A vacuum leak would skew the readings toward zero in/Hg, not off the scale.
Old Jan 13, 2024 | 08:32 PM
PinkVetteLady's Avatar
PinkVetteLady
Brake cleaner works great too... anything that is combustible will work
PVL
Old Jan 14, 2024 | 11:20 AM
SupremeDeluxe's Avatar
SupremeDeluxe
I don't know what you are working with, but if it's a base engine car then 17-21" is the range, others lower as cam performance level increases. I just went through this with my 63 L75 that had a L-79 cam added at some point, as well as the heads swapped. Turned out to be very subtle interference with the oil separator in the valley, preventing a seal at the bottom of the intake ports. Was sucking oil vapors at 6,8,5, and 7 and oiling up the plugs. Had only 13" of manifold vacuum. There is no way to diagnose a leak at the bottom of the runners except for disassembly and visual inspection. External (atmosphere-side) leaks are easy to find.
Old Jan 14, 2024 | 03:50 PM
barkingrats
OP posted a followup in a new thread:
https://www.corvetteforum.com/forums...post1607425659
Old Jan 21, 2024 | 01:46 PM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Tuner in Tampa
To save a lot of time, Id get a smoke machine off Ebay or make one off a Youtube video. Given the age of the car, you may have more than one cracked hose, and the smoker will help you find it.
EMAIL: Tuning@TampaTuning.com
Website >>> https://shop.tampatuning.com/
CHECK OUT MY SHORTS : https://www.youtube.com/@tampatuning/shorts
Street Performance Tune Package starting from $390.00
Instagram: TampaTuning
Camaro Tuner in Tampa
Old Jan 22, 2024 | 01:35 PM
Jam421's Avatar
Jam421
In the past I've used Carb Cleaner....with a snorkel.... directly along the edges of the intake while idling & monitoring the vacuum gauge looking for a temporary spike. I keep a rag nearby and cleanup is easy. I imagine WD 40 is also an easy wipe clean. But first......check all your intake bolts especially the rear ones.
Old Jan 22, 2024 | 02:47 PM
Tampa Jerry
Carb cleaner will work if you get the brand that is combustable. Some of the newer brands are non-combustable. They will clean pretty well, they just won't ignite. Jerry
To Vacuum leak
