More engine advice
New will be 64.
Wondering how much I would gain switching to true flat top pistons. This doesn’t seem like much dish to me.
Very low mileage engine. No ridge, and bearings were perfect when I dropped pan last year.
Not going racing, just looking for a little more power as I go through the gears.
Thanks!Tim
New will be 64.
Thanks!Tim
I think you would like the combination. Add a 151 cam from GM or a similar roller and you would like it more. May require 93 unleaded but that’s a small price to pay for a good boost in HP 👍👍
Others will jump in soon with recommendations
So moving compression by a point would give a little more power but not major I am thinking 5% but moving to the Vortec design which does offer better flow numbers will add some power also.
Where did your engine make 300/300? At what RPM did it see 300 HP? The Vortec heads are a big advantage up to 5,000 RPM but pretty much done by 5,500 on a 350. If that matches the cam you are running you might feel a nice seat of the pants upgrade but if your cam was making power well past 6,000 RPM before I would guess someone had worked on the heads you have already and opened them up for better than stock flow.
Something does not add up though because a 77 350 was a pretty wimpy engine not a 300/300 at the rear tire which would be more like 350/350 at the crankshaft. That engine can't be stock.
You might take a compression check prior to removing your heads. If it is 150 to 160 your heads are probably stock. If it is 175 or better the chambers are not 76cc or maybe your pistons are not flat tops but are domed.
As mentioned, your existing engine is much stronger than expected so something is modified to give you 350 HP at the crankshaft.
A friend built a couple 383 engines for his boat a while back, used Vortec heads on them. He called and was concerned because it had 200 PSI compression with flat top pistons, he was afraid it was going to have detonation issues but ended up running really well for him. His cam was the bone stock GM Marine cam so it had high compression.
Reverse Cooling was only used on the LT1 engines from the 95-99 dates, after the Gen 1 small block and before the LS engines came along.
Both hp and torque were strong by 3000 and I wouldn’t let him rev it over five. Both had peaked by then.
I don’t know how the numbers were so high with a stock replacement 350. When I pulled the heads it had mildly dished pistons with 76 cc heads.
When I made the initial post I had decided on the vortec heads, based on a couple articles I read. I was undecided on changing pistons too
to get full 10:1.
I decided this is my chance so I ordered pistons and pulled the engine. There is no ridge, or any sign of wear, and pistons are standard,so I continue to believe this is a very low mileage engine.
Will let you know in a month or so how it turns out.
Maybe I was just lucky but never had troubles with PotiSpark
Who was the GM genius that decided to place the distributor under the water pump and the ECM computer under the battery?
Sharp color combo but ran out of garage after getting a C6 and growing list of drivers in the family. Good problems to have 😃
It has just a few thousand miles since new.
For less than 1000 I can have about 400 hp which is more than I need. It should have even more bottom end, which was pretty good before.
For that money I couldn’t even get the machine work done.
You can get a decent 400 HP 350 with a decent top end better flowing heads and a bigger cam. intake selection a little tricky for best performance vs hood clearance on C2. if you have a good short block that is a reasonable way to go. But as you try and bump HP up the idle quality will go down with the cam selection
Vortec heads do flow better than most previous GM iron heads even the Bowties. head flow IS the big deal for making power.
Vortec 350s in trucks did have a reverse direction water pump due to the serpentine belt set up but not reverse coolant flow.
