engine weight
Old Feb 2, 2024 | 12:49 PM
CHEVY-FAN's Avatar
CHEVY-FAN
Active Streak: 90 Days
Default engine weight
Can the use of quickjack cause any body damage because of overhang front and rear.
Old Feb 2, 2024 | 12:50 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if your frame is rusted and about or fall in half then maybe
Old Feb 2, 2024 | 01:15 PM
leif.anderson93's Avatar
leif.anderson93
If used correctly then the answer is "NO".
Old Feb 2, 2024 | 01:23 PM
CHEVY-FAN's Avatar
CHEVY-FAN
My frame is in good shape Iam just concerned about the overhang weight
Old Feb 2, 2024 | 01:29 PM
vjjack04's Avatar
vjjack04
You will be lifting the car at the frame rails, with the load spread across each side so it wont be a problem. the frame has support at the rear and nose.
Old Feb 2, 2024 | 01:41 PM
elwood13's Avatar
elwood13
Are you lifting just the frame with the engine mounted or the whole car? The reason I ask is when I had a rolling chassis minus the engine and trans up on the quickjack, I put the wheels/tires up on the front crossmember after I removed the the front suspension. It had the potential to tip with rear suspension still on the car. Otherwise, no issues.
Old Feb 2, 2024 | 02:11 PM
CHEVY-FAN's Avatar
CHEVY-FAN
The whole car, and the chance of stress cracks
To engine weight
