54 Ground Strap
Old Feb 20, 2024 | 11:08 AM
mreinecke's Avatar
mreinecke
Default 54 Ground Strap
I assumed the ground strap would connect at the upper mounting bolt of the starter, but none of the pictures that I have seen seem to do so and I cannot find any written reference one way or the other. Where does the ground strap run to, chassis, motor or what? I appreciate any input.
Old Feb 20, 2024 | 12:04 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You are talking about the battery negative cable? Bolt it to the engine. Electrically, it doesn't matter to which engine bolt it attaches. Pick something convenient.
Old Feb 20, 2024 | 12:38 PM
mreinecke's Avatar
mreinecke
Thanks, I am not really concerned about the quality of the connection. I assumed without asking that a judge would be looking for proper placement so let me change the question, does it matter for judging where the ground strap is connected?
Old Feb 20, 2024 | 03:57 PM
jim lockwood
HA! Well, given that it's only a 6 Volt system, you should be!
That said, Chris Sherman is your friend WRT judging points.
I'm a practical individual. I will connect the battery cables where they will assure the greatest amount of cranking current.
Old Feb 20, 2024 | 08:18 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
The battery ground strap is connected to the back of the transmission - in behind the dipstick tube
Remove all the paint on the transmission
sequence is bolt, lock washer, dipstick tube, negative cable, transmission.
Chris
TiN Restorations
Plano IL
Old Feb 22, 2024 | 06:45 PM
mreinecke's Avatar
mreinecke
Thank you for that Chris, I appreciate the detail, it's exactly what I was looking for. As always, your expertise is appreciated.
Jim, I didn't phrase the response very well, I've had my share of 6 volt vehicles over the years and recognize the importance that you stress of a good ground. What I meant to say was I have a good understanding of how to properly ground, I'm now just looking for the where. Thanks.
To 54 Ground Strap
