Fuse block
Old Feb 21, 2024 | 02:02 PM
raypilot65's Avatar
raypilot65
Default Fuse block
Struggling with trying to get the new fuse block into the firewall. Does anyone have some tricks or tips?
Old Feb 21, 2024 | 05:26 PM
raypilot65's Avatar
raypilot65
Ok, I got it in. Removed the firewall insulation and managed to get it in. Helps to bend the harness so it lays flat before putting the screws in. I used a wire to make sure I had the alignment right. Now I'm trying to determine which harness goes where. Since I took it apart long
ago and didn't mark it I'm not sure. Looks like the engine harness goes inboard and the front light harness goes outboard.
Old Feb 22, 2024 | 10:10 AM
raypilot65's Avatar
raypilot65
Can someone please look at their C2 and follow the fwd lamp harness to the fuse block. I think it goes to the drivers side of the fuse block. The engine harness plugs into the inboard side.
Old Feb 22, 2024 | 10:21 AM
smacota1's Avatar
smacota1
I will take a look this afternoon when I get back. My car is a ‘65 with factory air.
Old Feb 22, 2024 | 12:39 PM
R66's Avatar
R66
On R66, the headlight harness connector is to the outside (fender side) and the engine harness is to the inside (engine side).
Hope this helps, can't give you a picture as I have cruise and a mess of wires above it.
Old Feb 22, 2024 | 01:11 PM
smacota1's Avatar
smacota1
I agree
here is a pic.
Old Feb 22, 2024 | 01:21 PM
mike mccagh's Avatar
mike mccagh
the configuration of the plastic housings are such that they can't be reversed. mike
Old Feb 22, 2024 | 03:48 PM
smacota1's Avatar
smacota1
That’s good info.
thanks
Old Feb 22, 2024 | 07:51 PM
raypilot65's Avatar
raypilot65
You are correct! When I first looked at it, I thought you could flip one over 180 deg and interchange them, but on second look, the key and corresponding notch prevent that. Thank you!
Old Feb 22, 2024 | 07:52 PM
raypilot65's Avatar
raypilot65
Thank you!
To Fuse block
