Gear question
Old Feb 23, 2024 | 03:44 PM
10sec89's Avatar
10sec89
Default Gear question
Currently I have the standard 3.70 in my L76 Roadster but would like to go to a 4.56. I understand there are different carriers and center sections, but don't know what one I would have or possibly need if I switched. Are the gears themselves relatable to a 10 or 12 bolt GM rear or special for the Corvette?
Old Feb 23, 2024 | 04:00 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
You going drag racing? You need a four series carrier.
@GTR1999 Will clue you in some more
Old Feb 23, 2024 | 06:17 PM
GTR1999's Avatar
GTR1999
Your profile says you have an 2002? What year is the car and what year diff is in it.
I don't know if any new vette 10 bolt 456's are left or made today. You can call Tom's differentials and see if they have any.
Depending on the power level of your car, trans, traction and usage, the 456 may turn your stock diff into "instant junk" unless you properly build it with good parts and procedures, and still nothing is bulletproof.
You want the best vette IRS diff with 456's, Tom's still has some 12 bolt 456 conversion gears. If you have never built a 12 bolt vette conversion, good luck. I have done a lot of them. They take a lot of time hand and machine fitting the parts- but they are the best. NOTE - 12 bolt conversions are no good with 63-66 housings in case that is what you have. Also, you will need a lathe, Bridgeport, and surface grinder and lastly the knowledge on how they are built.
Old Feb 23, 2024 | 09:26 PM
10sec89's Avatar
10sec89
I guess I need to update the profile. The 02 Z06 is gone and I now have a 65
Old Feb 24, 2024 | 09:35 AM
GTR1999's Avatar
GTR1999
65 Differentials were not strong. This was a transition year for the diff, moving away from the junk used in 63-4 but still carrying over some of the same issues. The posi case was changed to the first design Eaton but it was very prone to cracking. Once a crack forms and starts to travel it is a time bomb. It can not be drilled and welded it has to be replaced before the crack reaches the cross shaft bore and the case implodes.
If you find NOS or good used GM 456 gears you will need a 4 series posi case. The 4 series gears of that era were two designs, one bad and one better.
If you plan on racing the car you will need to make a lot of mods to keep it on the track, especially if it's original.
Old Feb 25, 2024 | 09:37 AM
Mike C#2's Avatar
Mike C#2
GTR1999 is the resident expert on the C2-C3 IRS. His advice is gold. What are your intended use for this car? If driving is involved, a transmission swap makes sense. With your 3.70 gears, a close ratio TKX will give you 4.56 launching with its 2.87 first gear and 2.56 cruising with it .68 OD.
My money would be on a case swap in the ‘65 housing and a TKX. And that’s exactly what I did on my own ‘64.
Old Feb 28, 2024 | 11:19 PM
GearheadJoe's Avatar
GearheadJoe
I fully agree with this approach. If you want the equivalent of a change to a 4.56 rear, keep the 3.70 rear gears and install a Tremec TKX with a 2.87 first gear (Muncies were either 2.20 or 2.56 first gears). And if the 2.87 TKX first gear isn't low enough for you, there is an option for a 3.27 first gear. The nice thing about the TKX 5-speed is that 5th gear is an overdrive ratio of about 0.68 or 0.82. The 0.68 5th gear would allow you to drive at highway speeds in relative comfort compared to the 1.00 4th gear of a Muncie.
To Gear question
