WCFB causing "stumble"?
In an attempt to isolate the cause of the stumble I ran a wire from my coil into the cabin. Today, I hooked up a ground wire to the Z-bar and connected them both to my Tach/Dwell meter temporarily mounted on my steering column. It allowed me to monitor the Dwell while it would stumble, to see if perhaps it was an electrical problem. I did it a number of times and the meter remained steady during the stumbles. I honestly believe it is fuel related and not electrical. It is more of an annoyance more than a problem, except when pulling out into traffic and needing to get up to speed quickly, etc. If I had access to another WCFB that I could install and test with I could confirm that carb is the problem. Alas, I don't have a resource to accomplish that and the cost for another correct one(this is the carb the car was born with) is about $800-$1K. That's a bit pricey for a test piece, unless that is the problem for certain and it needs replaced, which I would do if necessary.
MY QUESTIONS; Are there parts on this WCFB that wear out and can't be repaired/replaced? Has anyone had a similar issue and can share their experiences with me in resolving it? Other than this issue it runs fine, starts without problems,etc. I've been driving this car for nearly 50 years and am familiar with it's peculiarities. I would prefer to solve this one instead of living with it, if possible. Thanks for your time- lib
1) Check the accelerator pump.
2) This could be a stumble related to an off-idle circuit issue (progression). A big problem, historically, with Webers, but it is something I would check and see if that circuit/passage is functioning, correctly.
Good luck
The WCFB is very similar to the Rochester 4G and they were used interchangeably on GM assembly lines. Both have floats that are situated very close to the bowl sides and can easily drag upon them and cause your symptoms. Otherwise both carbs (WCFB & 4G) are some of the least problematic carbs out there. The other thing to look at is a hung up exhaust crossover that is making the intake and carb too hot.
If those check out I would take another look at ignition. One bad plug wire or plug insulator can cause a stumble that could be easily mistaken for a fuel problem. If you have access to someone with an ignition analyzer or oscilloscope it would be easy enough to rule out ignition and if you rule out ignition you will know that your WCFB needs expert experienced hands such as Robert Kunz.
Dan
i hope this helps Henry @ olescarb
Bill
