Temperature gauge
Old Feb 27, 2024 | 10:37 AM
Spowell637's Avatar
Spowell637
Default Temperature gauge
The electric choke on my 63 327 (Holley 80570 ) is defective so it was disabled until the replacement arrives. Immediately thereafter, while driving the temperature gauge is not working. Could the temp gauge be powered off the choke wiring?
Thanks in advance
Old Feb 27, 2024 | 11:22 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Thanks in advance
No.
Old Feb 27, 2024 | 01:51 PM
leif.anderson93's Avatar
leif.anderson93
As Jim stated...NO but you could have dislodged the temp wire tab from the temp sending unit...easy enough to check.
Old Feb 27, 2024 | 02:18 PM
65GGvert's Avatar
65GGvert
Not unless somehow they connected the choke wire to the pink gauges wire and you blew the fuse while you were “disabling” the choke. In that case, the fuel gauge wouldn’t work either. If the fuel gauge is working, the wire is probably not plugged onto the temperature sensor as they told you.
To Temperature gauge
