From: Edmonds Washington (Stunning view of Olympic Mtns and Puget Sound)
Updated '63 winter project
Hood had 100's of sun reflected blisters so after a weeks worth of sanding and cleanup looks presentible now. Also many hours of engine detailing with satisfactory results. begee22
Your car looks fantastic. Could you elaborate a bit about the "100's of sun reflected blisters" and the process of sanding them out. I'm guessing that you accomplished this without having to do any re-painting ?
Ted
Ted
Previous owner never covered air cleaner lid with hood up resulting in sun reflected blisters.Hand sanded complete underside using various sandpaper grits, re-painted with Krylon semi-flat black, finished with new rubber firewall seal. begee22
