[C2] Speedometer Cable Replacement
Old Mar 13, 2024 | 07:06 PM
pats67copo's Avatar
pats67copo
Default Speedometer Cable Replacement
Are there any how to videos available to replace the speedometer cable on a 65 four speed
Old Mar 13, 2024 | 07:57 PM
66jack's Avatar
66jack
Remove seat, lay on back, then with skinny forearms and fingers...just unscrew the finger nut from the speedometer, pull the cable out, insert the new one, screw the finger nut back on, put seat back in place
Old Mar 13, 2024 | 08:01 PM
63driver's Avatar
63driver
The inner and outer or just the inner?
Old Mar 13, 2024 | 08:07 PM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Take the extra time to pull the cluster out a bit. Remove the steering column and seat. Chance to inspect, change bulbs, dust and vacuum, check wiring, check oil line etc. You'll be good to go for another 10 years. And a new speedo cable to boot.
To Speedometer Cable Replacement
