[C2] Pully Alignment
Old Mar 21, 2024 | 01:32 PM
richopp's Avatar
richopp
Default Pully Alignment
I have been having some issues with water pumps on my '66 327/300. Without going into the whole story, I found out that in '66 there were 2 different spacings on the water pumps--5/16" and 7/16".
The alignment discussion we are having has to do with the fact that my car is a C-60 car, which means that the center pulley arrangement is 2 pulleys sandwiched together (2+1) as most of you probably know.
Does anyone know off the top of their head if the C-60 cars used the 7/16" pump due to the extra pulley so it aligns correctly? It is only an 1/8" but that obviously makes a lot of difference in alignment. I only today found out from Ron Burke at Chevy Cool that there are, in fact, two different ones.
Thanks to anyone who might know this.
(Sorry for the typo in the heading; I can't figure out how to fix it.)
Cheers
Old Mar 21, 2024 | 01:52 PM
leif.anderson93's Avatar
leif.anderson93
Cheers
Not exactly clear on what you're asking but I can tell you that the "326" water pump used on the L79 with A/C and power steering has the fan clutch mounting hub pressed 1/8" back into the pump shaft.
You could contact AG Rebuilders (formerly Arthur Gould) in Massachusetts with any questions.
(508) 210-0891
Old Mar 21, 2024 | 04:01 PM
richopp's Avatar
richopp
Thanks, will do.
Cheers!
Old Mar 21, 2024 | 09:16 PM
Mike C#2's Avatar
Mike C#2
If the flange is pressed back too far, you can use fan pulley spacers to move it back out, otherwise you will need to get the correct water pump or press the flange further on the one you have.
Old Mar 22, 2024 | 05:31 PM
richopp's Avatar
richopp
Thanks, Mike. We will make sure we check for that and use your remedy if needed.
Cheers!
Old Mar 27, 2024 | 11:25 PM
GearheadJoe's Avatar
GearheadJoe
Cheers
You are correct that there were two different spacings for the water pump flange that differed by 1/8". The measurement was from the block mounting surface for the water pump to the face of the water pump flange. From memory, I think the two values were 3-9/16" and 3-11/16", but I may not be remembering correctly. I can check this later if necessary.
The 300 hp engine used the smaller spacing for all configurations.
The reason for the difference is that the 300 hp engine used standard-groove pulleys and the L79 engine used wider deep-groove pulleys (except when equipped with A/C and power steering). For your 300 hp engine, you need the lower spacing, which I think is 3-9/16". For the 300 hp engine, it does not matter whether you have A/C and/or power steering. The proper distance for the water pump flange is the lower value.
The flange on the water pump is a press fit that can be set to either value. Unfortunately, if you want to decrease the value, you need to remove the water pump, remove the rear cover, and support the impeller while pressing the flange inward.
If you still have questions, I have all the necessary info at home and can look it up for you on Sunday when I get home.
To Pully Alignment
