[C1] The torque head gaskets
Old Mar 27, 2024 | 01:10 PM
John S 1961's Avatar
John S 1961
Default Re torque head gaskets
Is this required any longer?. I have a fresh rebuild 327 from a local outfit (five star engines) with about 500 to 700 miles on it.
Old Mar 27, 2024 | 01:14 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
You mean a retorque? Depends what head gaskets were used. I use Permatorque by Fel Pro on my builds and don't bother.
Old Mar 27, 2024 | 01:17 PM
John S 1961
Yes re torque. What if you don't know what head gaskets were used? Are HGs that need it even used anymore?
Old Mar 27, 2024 | 01:33 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
What does your engine builder recommend?
Old Mar 27, 2024 | 01:47 PM
John S 1961
Not available
Old Mar 27, 2024 | 02:28 PM
jforb's Avatar
jforb
Pull a valve cover, torque a few bolts to spec, if they don't move, then quit. If they do move, then you might want to torque all of them in order. I think you have to remove the exhaust manifolds to get the bottom row?
I've never retorqued them on a Chevy since the 1970s, but have on a few off brand cars, they needed it.
Old Mar 27, 2024 | 06:15 PM
Leo Guggenbiller's Avatar
Leo Guggenbiller
Too many unknowns for me. I would torque them for my own piece of mind, but that's me.
Drive em safe
Leo
Old Mar 27, 2024 | 11:21 PM
jim lockwood
Drive em safe
Leo
Good answer, Leo. It won't hurt anything to have done so if it proves to have been unnecessary. And it it was necessary, OP has prevented a future problem.
Win. Win.
Old Apr 4, 2024 | 09:44 PM
John S 1961
So would you loosen them and then re torque in order? Or just torque them up and see if they lost their torque?
Old Apr 5, 2024 | 05:58 AM
jim lockwood
Do NOT loosen. Just re-apply the recommended torque.
Old Apr 5, 2024 | 12:41 PM
PBF777's Avatar
PBF777
No matter what the gasket it always proves better (though not necessarily always required) to re-torque after the initial heat cycle if possible; and if noted, most always one will realize some gain in rotation on the fastener from the previous setting.
As for "re-torquing" a threaded fastener, that which is not of the "stretch to yield" or "turn to angle" types, or some which might posses hard setting locking compounds, or unique friction reduction coatings intended for one pull only, it is generally considered proper to back the fastener off, say 90 degrees plus or minus, and then re-pull to the intended torque value in a single and continual movement.
Though here (particularly with the GM product that exhibit having the threaded portion breaching the cooling jacket), a mitigating circumstance might be for those fasteners which incorporate a fluid sealing compound (vs. a lubricant) and whether this possesses the ability to tolerate this movement and still provide for it's function.
But, just pulling on an already torqued to "specification" fastener proves to be only a test for those which may have become "loose", not a good procedure for establishing that the fastener is still torqued to spec.
Scott.
Old Apr 6, 2024 | 05:26 AM
jim lockwood
Scott.
First I've ever of such a thing. What is your logic behind that procedure?
Old Apr 6, 2024 | 08:53 AM
BrandonU's Avatar
BrandonU
Cylinder head re-torquing is generally not needed if the correct procedure and components are used initially. The only time I re-torque would be on a copper head gasket in an extreme cylinder load situation. (supercharged pulling truck for example). I do not re-use factory head bolts though. I do often re-use ARP or A-1 bolts/studs if they are in good shape. When re-torquing, the proper procedure would be after the initial heat cycle or dyno load, back to room temperature, back off each nut or bolt about an 1/8th of a turn, and pull to final torque in 1 sweep. This is done in proper sequence. The reason to back off is to overcome the initial friction to get the fastener turning. you do not want to "relax" or completely unload the nut/bolt as this could break the seal it has.
Brandon Unklesbay
All-In Performance, LLC
Old Apr 6, 2024 | 09:09 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
I would also consider whether this rebuilt engine used iron heads or aluminum heads, what head gaskets were used and what were the block deck and head surfaces spec'd to before assembly, and whether torque to yield bolts/studs are the hold down fasteners in question. Additionally, if the engine is not a super high performance engine and with or without power adders might also make a difference, as well as what kind of duty it is being used for (e.g., tractor pulls). So way more information would be needed to provide an informed answer. But if it's just a warmed over SBC and was assembled with reasonable care - in short I wouldn't bother. But if I did I would just check a few cold and if any moved I would circle pattern recheck them all. But I would also be careful not to over torque them by pulling past the torque spec to 'see' where they broke free. Also keep in mind that the head bolts that penetrate the water jacket may wind up having their sealant disturbed and could possibly leak after being disturbed.
Old Apr 6, 2024 | 10:00 AM
ChrisBlair's Avatar
ChrisBlair
In case it needs to be said...do not re-use torque to yield (TTY) or stretch bolts. The bolts elongate.
To The torque head gaskets
